Aeon Labs controle module via RS32 possible
Edwin2008
Post by Edwin2008 »
As far as i understood the best solution for controling zwave is the "Aeon Labs Z-Stick", but this is USB :(
Is there a RS232 version of the "Aeon Labs Z-Stick"?
** edwin **
mhn
Re: Aeon Labs controle module via RS32 possible
Post by mhn »
I have never heard about one, hence I don't think so.
http://www.aeon-labs.com/site/products/category/1/
LostDreamer
Post by LostDreamer »
The usb stick is works as a virtual serial device,
you can communicate with it as you would with a serial device.
[url=https://www.viagrasansordonnancefr.com/commander-sildenafil-100-q-sirve/]commander sildenafil 100 q sirve www.viagrasansordonnancefr.com[/url]
Edwin2008
Post by Edwin2008 »
i now but i would prefer a straight serial connection via an rs232 Ip server. So no USB->rs232 connection and driver problem's.
** edwin **
thats not possibile.
You can use any remote USB poort device like belkin or USBanywhere
Edwin2008
Post by Edwin2008 »
i was afraid that would be the answer :(
** edwin **
Mdamen
Post by Mdamen »
In theory it's possible, I haven't looked at it though. The z-stick just has an usb<>serial converter.
If you open one and make some pictures I could tell you where to wire it up (requires soldering some wires)
Edwin2008
Post by Edwin2008 »
Sorry, do nit own one (perhaps yet) but i'm sure you would make a lot of friends on the forum if that would be possible ;)
** edwin **
mhn
Post by mhn »
I have pictures of a Z-Stick.
This is the quality the forum allowed me. If you need better quality, we must find a way to give you the originals.
Regards
Morten
Mdamen
Post by Mdamen »
Thanks for the pictures.
Here's is my analysis:
There's a UART to USB chip located here:
And here is a piece of info out the datasheet:
As you can see these upper pins are serial data lines (RXD, TXD) and that would allow to hook the aeon labs stick up to a serial port.
This does require a steady hand though :-) Please note that you also need some power supply (5v) to replace the USB power supply.
All and all a bit of hacking, but it is do-able.
The full datasheet of the UART to USB chip is located here:
silabs.com/Support%20Documents/Technica ... cp2102.pdf
Edwin2008
Post by Edwin2008 »
do the connections need a sort of buffering to ptotect them?
would a 7805 or something like that be stable enough in combination with a standaard 5 v adapter?
** edwin **
Mdamen
Post by Mdamen »
There's no 'buffering' as in capacitors required. Just make sure the logic levels (the voltage level the rxd/txd pins use) are the same.
A 7805 with a few capacitors will suffice for a stable voltage supply (see datasheet for optimal circuit)
This would give the stick a boost, much better to handle.
Connected on a RS232-> TCPIP device you can directly talk TCPIP without the annoying drivers!
Also much more stable then USB->TCIP which requires even more drivers
I still don't understand why new devices like Zwave have USB?
USB is nice for connecting temporary things like Camera's and memorycards etc.
Sorry...... Its well known I dont like USB :)
These days it is hard to find a PC with an RS232 interface, that is why peripheral device manufacturers use USB.
Edwin2008
Post by Edwin2008 »
not totally agree on that. Most of the time you need a separate bezel for the serial port since the mb has often a connector on it. Beside that, when the stick is RS232 you could always use a standard usb->RS232 convertor without the hassle. Modding the stick from usb to RS232 takes more effort :)
** edwin **
Return to “Z-Wave Forum”
