Everspring doorsensor configuring OFF delay
mhn
Re: Everspring doorsensor configuring OFF delay
Post by mhn »
Have you tried associating a switch to the sensor?
Make the association between sensor and switch.
If you have a lamp on the sensor, you can see if the sensor sends on/off.
Regards
Morten
Imbrium
Post by Imbrium »
Hi Tane,
I'm not a guy that brakes his promises :)
Homeseer 2.5.0.1
Z-stick Aeon Labs Series 2
Drivers Z-stick on XP : http://www.aeon-labs.com/site/support/view/8/
Update Z-stick on XP : http://www.aeon-labs.com/site/support/category/4/
I also installed everything on my Win 7 machine (with the correct drivers of course)......same result.....
Hope this can make a breaktrough.....
Best regards,
Lode.
Imbrium
Post by Imbrium »
Hi Morten,
No i can't do that since i bought only a Z-stick and a sensor for testing purposes.
Altough i'm an ICT i can't see what's wrong here.
The sensor has been replaced so that's not the problem i think.
Thanks anyway..
Best regards,
Lode.
Is there a association with Homeseer?
You can check this in the association setting of the doorsensor.
See the last picture in my review
http://blog.tane.nl/?p=178
Without association Homeseer will never notice status changes.
Imbrium
Post by Imbrium »
Tane,
I made an association between the sensor and homeseer below is what i see....
I only see homeseer and not the sensor
Your picture shows both devices or is it ok so because now IT WORKS !!
The attachment is not uploaded.
Imbrium
Post by Imbrium »
Sorry, post is edited...
good to hear that it's working.
You can associate with more than one device.
In my case i have associated with homeseer (i can trigger events depending on the status)
Other device is a switch.
Both will work when Homeseer is not available the second association will still work.
Zwave associations are stored on the devices. This is why i love zwave. it will also work without domotica software.
Imbrium
Post by Imbrium »
Tane,
Thank you so much for your help and also the other members, thanks a lot.
I can continue discovering this wonderfull world of domotica.
Tane, i send you a pm.
Best regards,
Lode.
Return to “Z-Wave Forum”
