Visonic Powerlink2 Hacked
Moderators: Rene, Willem4ever
You all know that I recently bought a Visonic Powerlink2 with the reason to conect it to my domoticasystem.
You can see the earlier postings about it here
http://www.domoticaforum.eu/viewtopic.php?f=22&t=5624
Powerlink2
Powerlink2
Together with Digit (he did most of the work) we mananged to find a way to control the basic Powermax Pro functions via the Powerlink 2
Functions Like Arm Home-Away and Disarm bij sending a HTTP request the Powerlink.
POST .../mobile/login/index/?JsHttpRequest=12982287732070-xml HTTP/1.1
Accept: */*
Accept-Language: nl
Referer: http://xxx.xxx.xxx.200/mobile/login/index/
Content-Type: application/octet-stream
Accept-Encoding: gzip, deflate
User-Agent: blabla
Host: xxx.xxx.xxx.200
Content-Length: 42
Connection: Keep-Alive
Pragma: no-cache
Cookie: PowerLink=077d58c208ef9aaef1fe8d464015d929; mobile=e6efb2eae139ca6fe327b603d6c23e76
login=admin&password=admin&time=1298228773
Look at the username and password being sent to the Powerlink2, unencrypted and no HTTPS possible?
Visonic is not doing a nice job on this one!
Good for us though, soon more on the powerlink protocol and now a way to control the Powermax Pro will be available.
For more details check:
Digits Blog:
blog.hekkers.net/2011/02/21/controlling ... owerlink2/
Bwired Blog:
http://www.bwired.nl/weblog.asp?id=415
Re: Visonic Powerlink2 Hacked
Good to hear! Although I am still struggling with mine to get it up and running.
I do not find it that strange the password is not encrypted. All that basic authentication, typically used to exchange userid and password, does is obviscating the password using base64 encoding which is easily reversable. A problem although is that you can use HTTP instead of HTTPS to access the web interface. Is it possible at all to use HTTPS?
Esteban
Post by Esteban »
Great work guys! That is a nice addition for all the domonauts using this system. *thumbs up*
Rene wrote:All that basic authentication does is obviscating the password using base64 encoding which is easily reversable.
You're right, that's why I expected more than nothing from Visonic, cause that's what you get right now. It should have been more, not less.
Are you able to access the interface using HTTPS or only plain HTTP?
Yes, you can: :lol: (I'm serious)
BlaDeBla
Post by BlaDeBla »
Thanks guys, for the interesting developments. I also recently bought powerlink2 and follow this story closely.
Noel
Post by Noel »
Interesting.
Who (shop) is selling this Visonic Powerlink2 ?
See the other Powerlink2 topics for that.
But beware lots of people have trouble with the powerlink2 on a Powermax Pro
Looks like it has something to do with the firmware.
i have a new powermax pro anf works fine with the powerlink
Together with Bob, the owner of the webshop, I am trying to solve the problems to get the Powerlink2 up and running on my Powermax Pro. He has some panels were he could not get it up and running also. He is also in contact with Visonic but until now it is not clear what is causing the problems. So if I were you I would wait until at least it is clear why on some panels it is working and on other it is not.
fishtank
Post by fishtank »
Is there any update on the problems of Powerlink2 in combination with Powermax Pro???
I also have the problem that it does not work.
FT
I think my setting is the only one working, must have something to do with firmware.....
Is there a version number somewhere on the Powermax Pro
You can get version info of hardware and software using the remote programmer software.
hadyos
Post by hadyos »
Anyone can tell me what firmware version should I have in order to have powerlink2 work on Powermax Pro?
I'm using the remote programmer software from Visonic.
Thanks,
Yossi.
No, even Visonic does not tell or know this, and of the word "Service" they never heard of :(
Like I told before, Visonic is selling the powerlink2 and does not deliver a manual with it.
