FloorPlan Web Interface
I wanted to share some info about a project I'm working on.
watch the video and let me know what you think.
It does work on the iPad except for the dragging, working on a fix for that as we speak.
bottelier.com/imagestore/domotica/floor ... orplan.mov
Re: FloorPlan Web Interface
Looks real good, would be a nice addition to Plugwise
I finally got the ipad version working
While in edit mode on the ipad it will use an other html file to do all the work.
In the left menu i made a java-script detection to check if its an ipad, or some other browser.
The edit link will then point to either edit.html or ipad.hmtl
the video i made is horrible, but its hard controlling an ipad while recording with an iphone4
But i think its decent enough for you all to have a idea of the whole thing
watch the video at
bottelier.com/imagestore/domotica/floor ... n_ipad.mov
the video has no sound as it all speaks for itself
Gand
watch the video at
Gand
Sweet, looks real usable.
I just checked my samsung galaxy S (android) and it seemed to be working on that platform as well
could not doe a propper check, cause of the little screen. but still i have high hopes it will work on android tablets
Gand
Gand
Gand please translate it, cause is a english part of the forum (zie bovenaan: * Board index ‹ Hardware Forum (English) ‹ Plugwise Forum)
Keep forgetting its internationalPietjeNL wrote:Gand please translate it, cause is a english part of the forum (zie bovenaan: * Board index ‹ Hardware Forum (English) ‹ Plugwise Forum)
I'll try to remember, thanks for correcting me
What technologies did you use? The floorplan looks nice.
Its within the Plugwise webserver so i could only use html + Plugwise-C code and JavaScript
Images are made with floorplanner.com
Oke i think its finally done.
Check out the complete video on Full Movie
Check a real short ipad video on iPad demo
Or download the source on Download
Please leave a comment if you download it, i'd like to track if its used
For those who downloaded it allready.
There is a small update V1.1 (check Version.txt in the floor folder to see your version if version.txt does not exist you have v1.0)
The updates contains a change to the menu in view mode.
The off option is no longer visible when a device has a locked status.
You can use the same link to download the latest version
Download
Download
I'm trying your Floorplan addition at my Plugwise server.
When I copied the "floor" folder to my Plugwise WWW root, I only got 404 errors.
I editted your index.html, and it seems to be working ok now
Changed this
<title>Plugwise Floorplan</title>
<frameset cols='0,120,100%' border='0'>
<frame name='action' src='none.html'></frame>
<frame name='left' src='left.html?t=m&floor=0'></frame>
<frame name='page' src='main.html?t=m&floor=0'></frame>
</frameset>
to:
<frame name='action' src='/floor/none.html'></frame>
<frame name='left' src='/floor/left.html?t=m&floor=0'></frame>
<frame name='page' src='/floor/main.html?t=m&floor=0'></frame>
</frameset>
Wim.
Changed this
</frameset>
to:
</frameset>
Wim.
Putting a / behind floor would have worked
but this is a beter option made the change in the .zip file thats mentioned in the previous posts.
so people who download it now will have the new version
Your mentioned in the Version.txt
Thanks!
(btw: the Version.txt says "limbo", it's Wimbo
now it says Wimbo,
Well the file does not speak, but you know what i mean
