YouLess LS110 Energy Monitor
Rutger
Re: YouLess LS110 Energy Monitor
Post by Rutger »
Create two new virtual devices on the status page.
Copy complete script above.
Create an event, recurring, i.e: every 60 seconds
Add Action: run script
Create new one.
Name: i.e: Youless.vb
Open script window
Paste complete script and change ip address and both device codes A8 and A9 two new device codes you earlier created.
yellowbird
Post by yellowbird »
Rutger wrote:Hi Yellowbird,
Thnx for your script.
My counter have 3 digits behind the komma.
The youless counter is on 29661,544 kWh.
In Homeseer I see the value 296615. Your script have the komma 1 place too far to the right?
Do you have the same experience?
I assumed a fixed length for the total energy usage and it showed Wh instead of kWh, mine is just turned on since yesterday so I have very low kWh number. Here is an updated version that I think should solve it and also display the value in kWh.
Imports System.Net
Sub Main(parm as object)
Dim strUrl As String = "http://192.168.1.230/a?f="
Dim devIdCurrent As String = "A8"
   Dim devIdTotal As String = "A9"
Dim request As WebRequest = WebRequest.Create(strUrl)
Dim response As WebResponse = request.GetResponse()
Dim data as String = new System.IO.StreamReader(response.GetResponseStream()).ReadToEnd()
Dim s1 As Integer
Dim e1 As Integer
   Dim current As Integer
   Dim total As Double
s1 = data.IndexOf("pwr") + 5
e1 = data.IndexOf(",", s1)
current = Convert.ToInt32(data.SubString(s1,e1 - s1))
hs.SetDeviceValue(devIdCurrent, current)
hs.setdevicestring(devIdCurrent, current.ToString() & "W")
s1 = data.IndexOf("cnt") + 6
e1 = data.IndexOf("pwr", s1) - 3
total = Convert.ToDouble(data.SubString(s1,7).Replace(",",""))/1000
hs.SetDeviceValue(devIdTotal , total)
hs.setdevicestring(devIdTotal , total.ToString() & "kWh")
End Sub
freakstar
Post by freakstar »
How do i configure the virtual devices?
Rutger
Post by Rutger »
On your status page where all devices are visible, click on the left top on 'add device' and configure as you can see in the screenshot. Room and Floor will be different ofcourse.
No other configuration is necessarry. For the Youless script from Yellowbird, you'll have to add two virtual devices, like YL_Current and YL_Total.
The devicevalue and devicestatus will be updated when the script runs.
freakstar
Post by freakstar »
Trying to get this script back to work after an stupid delete action...
Created an event with the following script:
Imports System.Net
Sub Main (parm as Object)
	Dim strUrl As String = "http://192.168.1.9/a?f="
	Dim devIdCurrent As String = "Y1"
	Dim devIdTotal As String = "Y2"
	Dim data As String = new System.IO.StreamReader(response.GetResponseStream()).ReadToEnd()
	Dim s1 As Integer
	Dim e1 As Integer
	Dim total As Double
End Sub
Created two "Status only" devices Y1 and Y2 for the values. When I run the script my HS log says:
Running script, script run or compile error in file: GetPwr1006:Expected ')' in line 3 More info: Expected ')'
Overlooked the script now like 10 times but can't find this fault?
freakstar
Post by freakstar »
Ah ja het truukje was opslaan als .vb...
nikagl
Post by nikagl »
De code bevat nog een foutje volgens mij. Je pakt de substring fixed 7 lang bij het totaal gebruik. Dit zou e1 - s1 moeten zijn om de lengte van de string te krijgen...
Imports System.Net
	Dim devIdCurrent As String = "v4"
	Dim devIdTotal As String = "v5"
	Dim s1 As Integer
	Dim e1 As Integer
	Dim total As Double
	hs.setdevicestring(devIdCurrent, current.ToString() & " Watt")
	total = Convert.ToDouble(data.SubString(s1,e1 - s1).Replace(",",""))/1000
	hs.setdevicestring(devIdTotal , total.ToString() & " kWh")
End Sub
En voor degenen die deze code gebruiken, niet vergeten:
  • virtual devices aanmaken voor current en total
  • ip adres veranderen in youless ip-adres (192.168.1.9 vervangen)
  • v1 en v2 veranderen in de codes van jouw virtual devices
  • script plaatsen in scripts folder
  • event aanmaken dat script iedere X minuten runt
  • advies: zorg ervoor dat het event niet logt, anders heb je bij iedere execute een regel dat hij het script start
Voor dit alles ook nog even wat screenprints toegevoegd. Misschien handig voor diegenen die het willen gebruiken maar niet weten hoe...
Groet,
Nika.
7. Event Trigger.png (13.94 KiB) Viewed 35803 times
6. Event Properties.png (20.02 KiB) Viewed 35803 times
5. Virtual Device YouLess Total Options.png (16.53 KiB) Viewed 35803 times
4. Virtual Device YouLess Total Config.png (14.56 KiB) Viewed 35803 times
3. Virtual Device YouLess Current Options.png (13.29 KiB) Viewed 35803 times
2. Virtual Device YouLess Current Config.png (20.57 KiB) Viewed 35803 times
raymonvdm
Post by raymonvdm »
I just added this script to my HomeSeer and it is working fine :D
I also use two scripts to create a day usage counter (script was used for the NorthQ before, maybe it it not completely working due to DeviceString versus DeviceValue issues)
This one copies the current usage to another virtual device (running at 23:59)
hs.SetDeviceString("K74", hs.DeviceString("K76") )
hs.SetDeviceLastChange("K74",now)
End Sub
This one calculates the usage of the last 24 hours using the value saved in the day before (running at 23:54)
hs.SetDeviceString("K73", CStr( hs.DeviceValue("K76") - hs.DeviceString("K74") ) /100 )
hs.SetDeviceLastChange("K73",now)
End Sub
My devices are
YouLess_Total_Day_Usage	  0	                Beganegrond	Meterkast	YouLess_Total_Day_Usage	        K73	Status Only	 Today 23:05:50
Youless_Total_Yesterday	  39825,715 kWh 	Beganegrond	Meterkast	Youless_Total_Yesterday	        K74	Status Only	 Today 23:06:55
YouLess Current	          696 Watt         	Beganegrond	Meterkast	YouLess Current	                K75	Status Only	 Today 23:12:26
YouLess Total	          39825,786 kWh	        Beganegrond	Meterkast	YouLess Total	                K76	Status Only	 Today 22:52:26
freakstar
Post by freakstar »
Made some changes to get the script ready for HomeSeer 3:
Imports System.Net
   Dim strUrl As String = "http://192.168.1.14/a?f="
   Dim devIdCurrent As String = "117"
   Dim devIdTotal As String = "120"
   Dim s1 As Integer
   Dim e1 As Integer
   Dim total As Double
   hs.SetDeviceString(devIdCurrent, current & " Watt", True)
   hs.SetDeviceString(devIdTotal , total & " kWh", True)
End Sub
Using the Reference ID to point to the virtual devices, don't know what to use to get it working with the Technology Address attribute?
raymonvdm
Post by raymonvdm »
I migrated to HS3 and these are my YouLess Scripts the last one is working fine now the other two in need to verify
These are the scripts
Maak_Nachtstand_Youless.vb
hs.SetDeviceValue("449", hs.DeviceValue("448") )
hs.SetDeviceLastChange("449",now)
End Sub
Maak_Verbruik_Youless.vb
hs.SetDeviceValue("450", CStr( hs.DeviceValue("448") - hs.DeviceValue("449") ) )
hs.SetDeviceLastChange("450",now)
End Sub
youless_update_HS3.vb
Imports System.Net
   Dim strUrl As String = "http://192.168.140.150/a?f="
   Dim devIdCurrent As String = "447"
   Dim devIdTotal As String = "448"
   Dim s1 As Integer
   Dim e1 As Integer
   Dim total As Double
End Sub
raymonvdm
Post by raymonvdm »
Is there somebody with a little more scripting experience who can fix the first two scripts for me. I want to create a value each night around 23:59 and extract the next night value from it to get a day usage of the last day
egbertje
Post by egbertje »
This is an old topic but i am totally new to Homeseer and i have a problem with this script.
It all works but when i want to log the data for example to use in Jon00 database or in Imperihome or in Device history, nothing will be logged.
I think the problem is that there is coming no data in the Value field , only in the "string" field, and the plugins get the data from the Value.
Is this possible to change something in this script?
Homeseer 3 on andere Intel Nuc/Win10
Plugins Imperihome Jowihue Rfxcom Pushover P1
RFXcom V3 Visonic Powermax+ some KaKu
erwindr
Post by erwindr »
The device string is set correctly, but the value is indeed empty. Just a small change in the syntax.
Edit this:
to
hs.SetDeviceValueByRef(devIdCurrent, current, true)
and
to
hs.SetDeviceValueByRef(devIdTotal , total, true)
HS3 Pro 3.0.0.298, W10 on Atom x5-Z8300
SqueezeBox, UltraM1G3, UltraMon3, Z-Wave
HS2 Pro 2.5.0.80, W2k3 on AMD X2
X10 CM11A/CM12U, SqueezeB, UltraMon, tenHsPower, UltraM1G, SqueezeBox
djanssen
Post by djanssen »
Hi there,
This is my script that I use to have current and total kWh values in Homeseer 3.
Is there anybody who have added also his gas meter reading in HS3 with a Youless monitor and is willing to share his script for this?
Maybe some other scripts for HS3 like last day usage / current day usage that are used are welcome as well
Daan
