Someone can help me to config my Foscam camera in Domotiga?
My config is:
Type: Stream MJPEG
Stream URL: http://192.168.1.80/videostream.cgi?user=xxx&pwd=xxx
I also tried:
Type: Stream MJPEG
User: xxx
Password: xxx
It works well in VLC and also in CVLC.
Tks, Max
Foscam camera
Moderator: RDNZL
Re: Foscam camera
Streaming URL needs to look like this;
rtsp://192.168.1.80:554/play1.sdp
Check in your Foscam config/manual what the port (554) and what the name of the stream is (play1.sdp)
- Member
Re: Foscam camera
I have the foscam working with:
Type: Stream MJPEG
Stream URL: http://192.168.1.nn/videostream.cgi
User: xxx
Password: xxx
So in that format it should work, do the example cams work?
Type: Stream MJPEG
User: xxx
Password: xxx
