2 dimmers on the same lamp. 1 Jung dimmer and one KAKU dimme
Forum about Click On Click Off (KAKU), Home Easy and related hardware.
OoM_JaN
Post by OoM_JaN »
Is it possible to use a classic dimmer switch in combination with a KAKU dimmer switch in a Multiway switching ciruit?
I want to use my dimmer-switch on the wall or the KAKU dimmer switch. I found some schematics but I'm not sure wether this will work or not. My current dimmer-switch is from Jung.
Re: 2 dimmers on the same lamp. 1 Jung dimmer and one KAKU dimme
No, because a standard dimmer switch is a slider and the dim function with KaKu isn't done that way.
OoM_JaN
Post by OoM_JaN »
And which device makes it impossible. Is the system itself impossible to create or is there the KAKU device the limitation? Or do I need a special wall dimmer?
OoM_JaN wrote:And which device makes it impossible. Is the system itself impossible to create or is there the KAKU device the limitation? Or do I need a special wall dimmer?
Can't say like that because both can do the funtion but they do it in a different way. Look at the manual ( http://www.klikaanklikuit.nl/service/ge ... wijzingen/ ) and see how KaKu does it and decides which you want to use and/or find a solution thst works for you
Return to “Click On Click Off & Home Easy”
