Fibaro rgb module with homeseer?
- Advanced Member
- Contact:
Dear all,
Anyone tried the new fibaro rgb module especially in combination with homeseer? Or any other comments on this unit. It looks very promising to me. But i doubt if it works in homeseer 2.
Regards
Bart
Regards
Bart
(ON ESXI )on NUC
(ON ESXI )on NUC
Re: Fibaro rgb module with homeseer?
I don't use Homeseer. Am also eagerly expecting this module. Judging by the manual it is capable of mimicking itself as a dimmer with multiple channels. This would make it simple to integrate with current Z-wave libraries I guess. Unfortunately in the "normal" way it is using a color control set Z-wave command class. I haven't seen this on any other z-wave device so far. So I *guess* Homeseer would need an update for this. And also I would need to get information from somewhere how to implement this in my own z-wave library...
Still... the hardware itself is pretty impressive. All crammed in a small module! Fibaro home center suddenly became a lot more interesting!
- Advanced Member
- Contact:
Dear all,
The module (fibaro rgbw) works great with homeseer. It created for dimmer devices to control the colour channels a main controller and 3 powermeter devices. Great News..
I just bought one for testing amd this is the conclusion
(ON ESXI )on NUC
(ON ESXI )on NUC
Can you also go to a certain color without adjusting each of the channels?
- Advanced Member
- Contact:
No, not with homeseer. I think you need scripting. In addition there are builtin modes such aa colorfade however this is a parameter and not accessible by scripts. Maybe someone else have an solution.
Regards bart
Regards bart
(ON ESXI )on NUC
(ON ESXI )on NUC
Bart,
Is there some option to show some z-wave "on-the-wire" logging? I am curious how Homeseer is sending a specific channel change (R or G or B) to this device. Got one also and it only seems to respond to SWITCH_MULTILEVEL_CHANGE and BASIC_SET but only for all the channels (so I can only dim white light on an RGB strip). If you have some raw debug logging this would be fine. I can integrate this in my driver / maybe open-zwave driver.
Especially interested if it's using the COLOR_CONTROL_SET ...
- Advanced Member
- Contact:
Airox,
This kind of logging can be enabled in the homeseer ini. Dont know the exact entry but if u google it you will find it. I can remeber I used this before.
regards
Bart Bakels
regards
Bart Bakels
(ON ESXI )on NUC
(ON ESXI )on NUC
Bart,
The problem is... I don't have Homeseer
I'm just interested in a piece of logging to see which bytes get send when you turn on a channel (for example red). I can reverse engineer this to get a hang of how the module works and implement this on the open-zwave driver.
Greetings,
Gijs
Greetings,
Gijs
Did anyone ever managed to use the "fireplace, storm, rainbow, police lights" ?
http://forum.micasaverde.com/index.php? ... #msg125234
- Advanced Member
- Contact:
Yes i managed to implement this in HS3, by a script, and since the newest zwave plugin via events (set configuration parameter).
parameter 72 to value X (programma)
I use this for alarm tripping (police program)
Bart
Bart
(ON ESXI )on NUC
(ON ESXI )on NUC
Would you mind sharing the script ? so i can see what values is can use and to set the valuesbartbakels wrote:Hi,
Bart
- Advanced Member
- Contact:
You dont need the script , its a zwave action in the events now.
Bart
Bart
(ON ESXI )on NUC
(ON ESXI )on NUC
Aha, but where can i find the values i did not find them in the manual of the RGBW modulebartbakels wrote:You dont need the script , its a zwave action in the events now.
Bart
Values 1-10.
6= fire-like light
7= kind of lightning, random white flashes and then slowly dimming blue light
8= rainbow with bright colors
9= rainbow with softer colors
10= rapid flashing red/blue/white
I only have an rgb strip attached to it, play with the values.
6= fire-like light
- image.jpg (70.97 KiB) Viewed 20925 times
