Buienradar monitor HS3 plugin
Moderator: labium
Re: buienradar monitor hs3 plugin
i t will take some time to see which dll's i have to distribute with this dll if you dont run visual studio on your computer
http://msdn.microsoft.com/en-us/library/8kche8ah.aspx
http://msdn.microsoft.com/en-us/library/dd293575.aspx
http://msdn.microsoft.com/en-us/library/dd293565.aspx
i think but dont know for sure you have to download and install this c++ redistributable.
http://www.microsoft.com/en-us/download ... x?id=40784
Just tried:
Initializing plug-in(2): BuienRadarGps Instance::Could not load file or assembly 'SplineFormCpp2.dll' or one of its dependencies. The specified module could not be found.0STACK:Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
- Advanced Member
- Contact:
Still the same issues as well, btw are u running on 32 or 64 bit. Im on 64. I had some issues with jon00 apps also. He needed to rebuild the exe to solve this, had something todo with build settings in C
Regards
Bart
Regards
Bart
(ON ESXI )on NUC
(ON ESXI )on NUC
Re: Buienradar monitor HS3 plugin
it runs on windows 8.1 64 bit . according to the platform toollset the 2013 version of the c++ redistributable should do it, did You restart the computer ?
i will now try to compile it with the dependencies as in this response is suggested
http://stackoverflow.com/questions/1970 ... o-msvcr100
- ccp2.PNG (45.34 KiB) Viewed 16530 times
i did put the buienradargps on a remote computer with vista 32 bits, i got the same error the slineformcpp.dll or it dependicies couldnt load. but after downloading c++ redistributable for visual studio 13 file version version 12.0.2501.1 it worked.
- Advanced Member
- Contact:
Labium it works , thnx! . Important is that you install the 86 version even on a 64 bit machine.
However i dont see any errors and do see graphs. The status device still says disconnected
Regards
Bart
Regards
Bart
(ON ESXI )on NUC
(ON ESXI )on NUC
Same here!
Graphs but disconnected..
Thx for helping out!
if you didnt ask anything i wouldnt have learnt anything.
- Advanced Member
- Contact:
hehe, lol,
but does it work for you, the status device labium?
regards
bart
regards
bart
(ON ESXI )on NUC
(ON ESXI )on NUC
Hallo,
Ik wilde het script installeren maar mis een aantal files in de zip
alleen de hspi_buienradargps en 4 files in de in de js map zijn aanwezig
Groet
Ed
Groet
Ed
this forum is in english please. i think you downloaded the first one not buienradar1.0.0.5.zip
the status device is green with me, but it is Always green so i dont know if it is a new status or old one , once introduced , i will look in to it.
