GreenWave Unknown (powernode)
FoRMaTC
Post by FoRMaTC »
I bought two powernodes (6 ports) Nuon aka Greenwave.
They have different firmware versions and the settings are different as well in openzwave control panel (see attached photo).
The problem I have is that I can't reset the values like the other powernode and also a lot of unknowns are there
Is there a way to put a new firmware on there?
Bjorn
FoRMaTC
Re: GreenWave Unknown (powernode)
Post by FoRMaTC »
140 views..... no one?
GertK
Post by GertK »
You cannot update the firmware of the Greenwave Powernodes. Why would you want that ?
You can lookup how to configure them elsewere in this forum. The most important setting is parameter 1 the no communication timeout in minutes. If you do not poll the device before this timer times out, the big green light around the mains switch starts flashing.
Gert
FoRMaTC
Post by FoRMaTC »
I understand but why do I have no totals with node8 while I have them with node7.
Also I have different Library/ Protocol and Application versions between node7 and node8
FoRMaTC
Post by FoRMaTC »
Also I can not read the configuration out of node8.
I will reset the device maybe that will help
uAlex73
Post by uAlex73 »
Do you have a copy of your zwcfg*xml? Then I can compare it with my powernodes (i got both 1 and 6 port versions).
FoRMaTC
Post by FoRMaTC »
I'm using domoticz and I assume it is in the Config directory
Attached the file
Bjorn
zwcfg_0x0161d745.zip
(3.43 KiB) Downloaded 538 times
FoRMaTC
Post by FoRMaTC »
Hoi,
Heb het al opgelost :-)
Aan de hand van http://www.domotiga.nl/projects/domotig ... _OpenZWave (Unknown device in Z-Wave Commander):
<Manufacturer id="0099" name="GreenWave">
<Product type="0002" id="0002" name="PowerNode 1 port" config="greenwave/powernode1.xml"/>
<Product type="0003" id="0004" name="PowerNode 6 port" config="greenwave/powernode6.xml"/>
</Manufacturer>
is nu:
<Product type="0003" id="0006" name="PowerNode 6 port" config="greenwave/powernode6.xml"/>
</Manufacturer>
uAlex73
Post by uAlex73 »
Can you open a ticket with open-zwave, that they add this combination to their xml file? Else it is lost during every upgrade ... and you are helping other people too.
https://code.google.com/p/open-zwave/issues/list
And click on "New issue"
Return to “Z-Wave Forum”
