I am trying to run domotiyii.
I have installed it and the home page looks right but whenever I'm clicking a link on the main page I get error 404, for example : 'The requested URL /domotiyii/devices/index was not found on this server.'
I have not been able to check if JSON-RPC server is working properly.
domotiyii : url not found
Moderator: RDNZL
Re: domotiyii : url not found
Looks like you are trying to run DomotiYii not directly in the root of the webserver, but under /domotiyii.
You then need to edit the .htaccess file and add 'RewriteBase /domotiyii/' to it, just below the 'RewriteEngine On'
Ooooooohhhhh ! It works.
This may be added to the wiki.
It looks to be there already:
Use DomotiYii
After the Server and DomotiYii are installed and configured you can start using the DomotiYii client.
Go to http://serverip/domotiyii
