LED Stair project
Moderator: Mversluis
RdP
LED Stair project
Post by RdP »
Hi Guys,
I did a lot of HS3 plugin development the last months (Caddx/Networx plugin is nearly done:-))
Now I want to start with a new, completely different project. Led strips on my stairs !!!
So I know there are a lot of experienced guys here and I have some question for them:
- I decided to use dimable white led strips (no color) just don't what is better, warm or cool white. Any suggestion ?
- I need strips of different sizes (80, 79, 71 and 68 cm) What do I need to buy short strips, long strips, is it easy to make them the right size?
- I have 14 staircases, so 14 led strips need to be connected. Can I do this in parallel, or in serie ?
- Which power adapter to use ?
- Which fibaro (zwave device) used to control (dim) the led strips.
- My stairs are in 3 sectors divided, so may be I want to control the 3 sectors independent from each other. What will make this different in term of devices needed.
- IP20, IP44, IP65 ?? What do I use ?
- How many leds per meter is sufficient? I wil use a 'profiel' to put the strips in.
- What's a good/cheap (Dutch) shop to order the stuff
May be other question will pop up or may you might have some other advise I need to think about, which I'm not aware of.
Many thanks in advance....
Akatar
Re: LED Stair project
Post by Akatar »
if you have really 14 staircases then you must live in a very large house (building)
i would choose 24volt leds, warm white and then you need just one fibaro rgb module to control them all (you can control 3 zones)
how many leds per meter? thats hard to say, it depends how many light you need.
and ofcourse you need a 24volt adapter to power it all
RdP
Post by RdP »
Akatar wrote:i would choose 24volt leds, warm white and then you need just one fibaro rgb module to control them all (you can control 3 zones)
Can you explain how I can control 3 zone independently with one Fibaro RGBW controller ?
Akatar
Post by Akatar »
with the rgb module you can control 1 rgb stripe (that are 3 colors) three white stripe are also 3 colors (the same)
so 1 rgb or 3 white is the same
only:
white 1 is R
white 2 is G
white 3 is B
and also there is a fourth one, W (i forgot that fibaro is a RGBW module)
so you can control 4 white leds stripes
vincenttor
Post by vincenttor »
Why don't you use a Arduino for controlling ?
It even can support PWM outputs for example to use with RGB LED.
And if you want to go crazy , you can use DMX to control them.
There is coming a plugin to control DMX build from a simple arduino shield + arduino, possibility's are almost endless then.
It is way cheaper as fibaro stuff or any other brand and i think worth a shot.
I was planning to do this as well, using small sensors maybe pressure sensors beneath the steps so they light up at X pressure.
The LED strip, most of them , depends what sort of LED you have are ready to cut off every 5 - 7 CM.
And how much LED per meter , i don't think you want to many or they have to be dimmer always.
Same with how to connect series or parallel, this depends of what the controller can accept for usage.
I guess if you use a LED profile, there mounted downwards, you can probably get away with IP20 if its for inside.
Outside is a different story.
Henk_J
Post by Henk_J »
Not much involvement for domotica but the result is great. I just used this module, works like a charm....
e-stynus.com/index.php?main_page=produc ... 2cda7033ba
Fantic
Post by Fantic »
Using 3528 strip with 150 leds per meter would be more then enough light, what I was planning for the same project is a Aluminum L (15 or 20 x 10mm) strip long edge used to put the LED strip and holes for mountingto the underside of the steps with the 10mm side to cover the direct light.
I have done this already in my kitchen and must say the result is not bad at all, on the picture it is dimmed to 40%
Kitchen with LED light under cabinets
Regards, Maarten.
RdP
Post by RdP »
Akatar wrote:with the rgb module you can control 1 rgb stripe (that are 3 colors) three white stripe are also 3 colors (the same)
only:
white 1 is R
white 2 is G
white 3 is B
Ordered the strips and RGBW device. will post some pictures later this week.
Thanks for a the help....
RdP
Post by RdP »
As promised a picture of the result. I'm pretty proud of the result.... :)
freakstar
Post by freakstar »
Nice Rien!
Do you have some more (detailed) pictures of the strips, the profiles and the cabling?
Post by Harry »
how do you switch them , by movement detection ? looks great :D
simjoc
Post by simjoc »
Looks very nice!
Looks very nice indeed. Well lit and not to bright
RdP
Post by RdP »
See attached photo. This is what I bought to put the strips in. For protection and a diffuse lighting.
These are not cheap, in facts it was about 60 % of the total costs. You can buy them at LedStripKoning.nl
I used a Fibaro RGBW devices to control the strips. I devices the stairs in 3 sectors and can control/dim the 3 sectors independently.
For now they are controlled by HomeSeer events, I will add motion sensors later but than also controlled by HomeSeer.
It's nice to control every step independently, but for me it's enough to have the stairs decided into 3 sectors.
