Switch updates wrong device?
Forum all about Z-Wave Fibaro
DJF3
Post by DJF3 »
Team,
When I manually switch 'switch-1', in HS3 'switch-2' goes to ON?
HS3 (latest)
Fibaro relay switch 2x1.5kW
Aeon Labs Gen-5 stick
> when I click ON for "switch-2" I hear the relay but nothing is connected
> when I click ON for "switch-1" the lights are turned ON
Now everything is turned OFF
fibaro switched off
fibaro switched off
> when I flip the switch that's connected to S1 & Q1, the lamp is turned ON but
in Homeseer DEVICE "switch-2" gets status ON, not device "switch-1"
fibaro switched ON
fibaro switched ON
Any idea why that happens? Nothing is connected to the Fibaro ports S2 and Q2.
raymonvdm
Re: Switch updates wrong device?
Post by raymonvdm »
I`m running HS3 Pro Edition 3.0.0.194 (Windows) with a UZB stick and you are absolutly right. I have several of the dual-relays (NOTE: FGS-221) and when i switch the overloop button the inloopkast becomes ON. But when i switch the inloopkast butten the inloopkast becomes on. It looks like something went wrong in a new update.
Did you noticed it is possible to upgrade the firmare on the root device. I just found out the new button
Changing the end-point does not make any difference
I also found this topic and placed an update to it http://board.homeseer.com/showthread.php?p=1191470
and take a look at http://board.homeseer.com/showthread.php?t=175414 i just updated and now the manufacturer changed to Fibaro
Update
It seems to be related to firmware 21 on the fibaro device. I also have two of them running firmware 19 and they don`t seem to be affected
I also filed a bug for this http://bugzilla.homeseer.com/bugzilla/s ... gi?id=2900
raymonvdm
Post by raymonvdm »
Added another dual-relay module (Firmware 22) and it is also affected bij the bug. Both buttons are updates as S2
To bad that HomeSeer is not responding to the bug i reported
raymonvdm
Post by raymonvdm »
Is it possible for other HS3 users to report if they have this issue. Maybe it is not 100% there on all setups?
vanisher
Post by vanisher »
same here..
raymonvdm
Post by raymonvdm »
vanisher wrote:same here..
Do you also have this issue in Domotiga ? If so then we need to file a complaint against fibaro and not against HomeSeer
vanisher
Post by vanisher »
No HS3..
Maybe i can give it a try with openhab, but I have some limited spare time at the moment.
Phaeton
Post by Phaeton »
Did you guys try to rescan the module after updating the zwave plugin. Had simmilar issues and new plugin version + full rescan fixed it.
groeten,
raymonvdm
Post by raymonvdm »
Phaeton wrote:Did you guys try to rescan the module after updating the zwave plugin. Had simmilar issues and new plugin version + full rescan fixed it.
I tried a full rescan of the network and it did not fix it
I tried a rescan on the device and it did not fix it.
Are you also using Firmware 21 / 22 for a dual relay device ?
Phaeton
Post by Phaeton »
I replaced them so I cannot check anymore. Homeseer now officially supports fibaro so it should work. Really strange. Had this issue as well with dimmer. Rescan fixed it as well.
Sorry I cannot help you further
I hope homeseer will look into this.
Verstuurd vanaf mijn M6752 met Tapatalk
groeten,
raymonvdm
Post by raymonvdm »
I just dusted off a RaspberryPI and tested using Domoticz and the device is working fine. When i switch button 1 device 1 is updated in Domoticz and if i switch button 2 device 2 is updates.
To bad HomeSeer did not yet replied on the bug i filed
DJF3
Post by DJF3 »
Similar issues described in the following thread: board.homeseer.com/showthread.php?p=119 ... ost1194551
Paul H te O
Post by Paul H te O »
I have 2 of them FGS-221.
One is Ok, the other one has the same isu as discribed here.
Is there a solution?
HS4 Windows 10 Pro
raymonvdm
Post by raymonvdm »
Paul H te O wrote:I have 2 of them FGS-221.
I have not found a solution yet. Mind to share the firmware verion of the units?
Paul H te O
Both are the same: Version: 3.42 (ZDK 4.54.1) Firmware: 2.1
HS4 Windows 10 Pro
Return to “Fibaro”
