Opentherm Monitor - Custom web pages
timoline
Re: Opentherm Monitor - Custom web pages
Post by timoline »
Is there a way to manipulate the global cfg array, so we can create a settings page ?
thanks
Yes, you should be able to access the cfg array from a *.tmpl file, just like you access the gui array.
timoline
Post by timoline »
hvxl wrote:Yes, you should be able to access the cfg array from a *.tmpl file, just like you access the gui array.
Accessing the global cfg array is no problem, but I need a small example to change(manipulate) the values (in a html form).
Is it possible for you to give a little example, with 2 or 3 fields?
timoline
Post by timoline »
Here is what I created so far:
https://github.com/timoline/OTGW
I refactored the web pages with bootstrap 3 and jquery
Keep in mind this is a very early alpha version and I cant test it for real......because I don't own a Opentherm Gateway yet. :D
Have fun with it....and of course, if you want to help.....you're welcome
timoline
Post by timoline »
Unfortunately, adding the settings (web)pages is a bit harder then I thought it would be... :oops: :roll:
Especially this is my first try ever with TCL and there is no good framework for web-forms (that I know)
Still not sure it works correct when changing the cfg array, maybe it should be saved to the config file too..?
I have just posted otmonitor version 4.3 on the otgw site. This version adds the possibility to configure most settings through the web interface. This new functionality has not been exhaustively tested, so use at your own risk. Please let me know if you run into any issues.
timoline
Post by timoline »
hvxl wrote:I have just posted otmonitor version 4.3 on the otgw site. This version adds the possibility to configure most settings through the web interface. This new functionality has not been exhaustively tested, so use at your own risk. Please let me know if you run into any issues.
First impressions..... looking great, thx :-)
Bororo
Post by Bororo »
Hi Schelte,
how to use v4.3 on Windows?
Do I need to configure something prior to run v4.3?
Many thanks in advance.
Opentherm Monitor v.4.3 error
Stingone
Post by Stingone »
Same error here on 3 laptops :(
Apparently I still had some half-finished code left in there. Please let me know whether 4.3.0.1 fixes the problem.
Stingone
Post by Stingone »
hvxl wrote:Apparently I still had some half-finished code left in there. Please let me know whether 4.3.0.1 fixes the problem.
Works :D many Thx
PietjeNL
Post by PietjeNL »
Strange, because i still get a error message.
Next attempt: 4.3.0.2.
Bororo
Post by Bororo »
Just to confirm that 4.3.0.1 and 4.3.0.2 working on my windows 10 machine.
Thank you very much Schelte
Stingone
Post by Stingone »
Same here working both :)
