- Make use of an external (google nest/tado) webserver.
- Connection to domotica via this server, or via IFTTT external server
- Tado: claims to have a public API, but no bindings in Domoticz or OpenHab
- Nest: presence-detection through motion sensors: expensive to cover more rooms
So besides those two very appealing but slightly distressing solutions I see the following options:
- eQ3 Max Cube based system (domoticaforum.eu/viewtopic.php?f=70& ... mp;start=0)
- Honeywell evohome Wifi (the newest sets do not use a separate gateway anymore)
Leaves me with the Evohome. Benefits:
- no external server No, when using the phone app, one need to register with a honeywell server
- binding in domoticz (assuming the out-phased gateway, but I just hope the Wifi-version has the same API
- Smart thermostat with learning capabilities
- Supported with smartphone app and IFTTT (in case one want to do some easy automation of less critical tasks
- easy to extend to multi-room (actually it is designed for this)
Any thoughts appreciated.
