Morning all,
Just thought I'd drop in the little Arduino code on ESP8266 hardware project that I have. For a while now I was running a string of 1-wire temperature sensors off of a Raspberry Pi, which were then pushed onto an MQTT bus. With a desire to retire the Pi, I moved on to an ESP8266, with some custom code (at https://github.com/kylegordon/mqtt_esp8 ... 20_arduino ). Unfortunately that code had some problems that caused persistent hangs and reboots of the ESP8266.
So the solution is the Homie framework from https://github.com/marvinroger/homie-esp8266/releases, and some simple code inserted. The end result is https://github.com/kylegordon/homie-ds18b20-1wire and it's been working great now.
Homie seems really nice, in that the device enters an initial configuration mode that can be detected through the a web app at https://marvinroger.github.io/homie-esp8266/ (for v.15), and then once attached the wifi and device configuration becomes persistent. There's also an Over The Air update feature that I haven't used yet.
My DS18B20 sensor code lives inside loopHandler(), and Homie does the rest. I've not had any drop outs, hangs, or reboots yet. At the moment I had to manually scan my 1-wire bus to get all the ROM IDs and hardcode them in, but one day I hope to be able to scan it automatically at bootup.
Homie and 1-wire
- Starting Member
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
