You can just play with all parameters to see what they do. To get what you want, set the start date low and the end date in the distant future (2^31 - 1 is far enough :-) ).
Timeless
Post by Timeless »
Mmh ok. My current start and end are actually empty. Maybe that causes the message aswell.
If the messages appears tonight. Then I'm going to set the start and end date. So I'm sure what the cause was. What is the syntax? Is it in epoch or string format (like 01-01-2018?)
"The greatest good you can do for another, is not to share your own riches, but to reveal to him, his own."
- Benjamin Disraeli -
Seconds since the epoch, as in:
date +%s
QuasaR
Post by QuasaR »
al_n wrote:Yes, I've got them
-rw-r--r--    1 root     root          7525 Dec 15 09:41 base-qb2-ene_3.0.29-880-0_qb2.ipk
-rw-r--r--    1 root     root        148428 Dec 15 09:41 boot-logos_1.64-ene_qb2.ipk
-rw-r--r--    1 root     root        206675 Dec 15 09:41 firmware-ma_1.74_qb2.ipk
-rw-r--r--    1 root     root        197400 Dec 15 09:41 flash-gui_1.648-ene-qeio_qb2.ipk
-rw-r--r--    1 root     root        562747 Dec 15 09:41 flash-qwidget-diy_1.161-qeio_qb2.ipk
-rw-r--r--    1 root     root         56154 Dec 15 09:41 happ-kpi_1.119-ene_qb2.ipk
-rw-r--r--    1 root     root        175568 Dec 15 09:41 happ-pwrusage_1.416_qb2.ipk
-rw-r--r--    1 root     root         52630 Dec 15 09:42 happ-scsync_1.102_qb2.ipk
-rw-r--r--    1 root     root         50385 Dec 15 09:42 happ-smartplug_1.90_qb2.ipk
-rw-r--r--    1 root     root        170268 Dec 15 09:42 happ-thermstat_1.554-trunk_qb2.ipk
-rw-r--r--    1 root     root         20054 Dec 15 09:42 happ-usermsg_1.36_qb2.ipk
-rw-r--r--    1 root     root         36968 Dec 15 09:42 happ-weather_1.68_qb2.ipk
-rw-r--r--    1 root     root         29711 Dec 15 09:41 hcb-bxtproxy_1.70_qb2.ipk
-rw-r--r--    1 root     root        111531 Dec 15 09:42 hcb-config_1.218_qb2.ipk
-rw-r--r--    1 root     root        149656 Dec 15 09:41 hcb-core_1.144_qb2.ipk
-rw-r--r--    1 root     root        115749 Dec 15 09:41 hcb-netcon_1.224_qb2.ipk
-rw-r--r--    1 root     root         56363 Dec 15 09:41 hcb-rrd_2.125_qb2.ipk
-rw-r--r--    1 root     root         23459 Dec 15 09:42 hcb-watchdog_1.40_qb2.ipk
-rw-r--r--    1 root     root         51561 Dec 15 09:42 hdrv-hue_1.61-eneDevices_qb2.ipk
-rw-r--r--    1 root     root         96858 Dec 15 09:42 hdrv-p1_1.363_qb2.ipk
-rw-r--r--    1 root     root        261129 Dec 15 09:41 hdrv-zwave_1.505-ene_qb2.ipk
-rw-r--r--    1 root     root         22132 Dec 15 09:41 kernel-module-ftdi-sio_2.6.36-R07-h18_qb2.ipk
-rw-r--r--    1 root     root         10500 Dec 15 09:41 kernel-module-pl2303_2.6.36-R07-h18_qb2.ipk
-rw-r--r--    1 root     root         14715 Dec 15 09:41 libhcb-xml_1.83_qb2.ipk
-rw-r--r--    1 root     root         82856 Dec 15 09:42 libpcre_7.6-r8_qb2.ipk
-rw-r--r--    1 root     root        103529 Dec 15 09:42 lighttpd-mod-hcb-web_1.4.33-26_qb2.ipk
-rw-r--r--    1 root     root        121967 Dec 15 09:42 lighttpd_1.4.33-17_qb2.ipk
-rw-r--r--    1 root     root       2817466 Dec 15 09:41 qt-gui_1.3733_qb2.ipk
-rw-r--r--    1 root     root      12272555 Dec 15 09:42 qt-libs_5.3.1-06-setpos_qb2.ipk
I think I can safely install all beside of firmware-ma. Any other thoughts?
Can you tell me how you retrieved those packages ?
I want to fetch the latest updates (3.7.8) and I have the VPN up.
Eneco will push those packages to your toon at some point. You'll get a message when they are ready to be installed.
packages (.ipk) will be downloaded to \HCBv2\tmp\opkg-cache by Eneco. Probably deleted after installation but you should be able to find it there at some point
Ierlandfan
Post by Ierlandfan »
happ-thermstat - 1.1117-ene-master is the latest, it's not updating printTableInfo, so without further investigation kinda useless. . I think if you have a boiler management description (or change config_happ_scsync.xml so it thinks you have) and disable Quby vpn who knows what happens.
What I don't understand is that this version of happ-thermstat is trying to query a lot of extended OT Id's but is not updating the table. Maybe we 're missing something.
{'dataId':'74', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 74: 00 00, VentilationHeatRecoveryConfig]'}
{'dataId':'202', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 202: 00 00]'},
{'dataId':'206', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 206: 00 00]'},
{'dataId':'208', 'value0':'00', 'value1':'00', 'updated':'0', 'description':'[ID 208: 00 00, vhrCoefficientOfPerformance=0.00]'},
Trying to control Eneco's "warmtewinner"?
shelbyZ
Post by shelbyZ »
Ok here it goes.
I've been reading this topic in and out.
I got a used Toon which stucks at the second dot(boot screen).
According to the person whom I got it from, it happend after a software update.
So far I managed to root the toon and edited the wlan config to match mine (the point it kept stuck at while booting).
I'm in as root but I guess it's corrupted because the iptables are empty and couldn't install dropbear.
 opkg install dropbear_2015.71-r0_qb2.ipk
Installing dropbear (2015.71-r0) to root...
Configuring dropbear.
update-alternatives: Linking //usr/bin/scp to /usr/sbin/dropbearmulti
update-alternatives: Linking //usr/bin/ssh to /usr/sbin/dropbearmulti
 Adding system startup for /etc/init.d/dropbear.
Collected errors:
 * pkg_get_installed_files: Failed to open //usr/lib/opkg/info/hcb-web.list: No such file or directory.
 * pkg_get_installed_files: Failed to open //usr/lib/opkg/info/flash-qwidget-whatstoon.list: No such file or directory.
 * pkg_get_installed_files: Failed to open //usr/lib/opkg/info/flash-qwidget-benchmark.list: No such file or directory.
 * pkg_get_installed_files: Failed to open //usr/lib/opkg/info/flash-qwidget-settings.list: No such file or directory.
 * pkg_get_installed_files: Failed to open //usr/lib/opkg/info/flash-qwidget-traffic.list: No such file or directory.
 * pkg_get_installed_files: Failed to open //usr/lib/opkg/info/hcb-core.list: No such file or directory.
 * pkg_get_installed_files: Failed to open //usr/lib/opkg/info/flash-qwidget-whatsnew.list: No such file or directory.
 * pkg_get_installed_files: Failed to open //usr/lib/opkg/info/flash-qwidget-eusage.list: No such file or directory.
 * pkg_get_installed_files: Failed to open //usr/lib/opkg/info/kernel-module-rt5370sta.list: No such file or directory.
 * pkg_get_installed_files: Failed to open //usr/lib/opkg/info/flash-qwidget-note.list: No such file or directory.
 * pkg_get_installed_files: Failed to open //usr/lib/opkg/info/flash-qwidget-smartplugs.list: No such file or directory.
 * pkg_get_installed_files: Failed to open //usr/lib/opkg/info/flash-qwidget-thermostat.list: No such file or directory.
 * pkg_get_installed_files: Failed to open //usr/lib/opkg/info/flash-qwidget-weather.list: No such file or directory.
 * pkg_get_installed_files: Failed to open //usr/lib/opkg/info/happ-telmi.list: No such file or directory.
I'm in as root but i'm as stucked as the toon itself.
keeps repeating the following:
INIT: Id "zwav" respawning too fast: disabled for 5 minutes
INIT: Id "logl" respawning too fast: disabled for 5 minutes
INIT: Id "conf" respawning too fast: disabled for 5 minutes
INIT: Id "kpik" respawning too fast: disabled for 5 minutes
INIT: Id "p1p1" respawning too fast: disabled for 5 minutes
INIT: Id "comm" respawning too fast: disabled for 5 minutes
INIT: Id "netc" respawning too fast: disabled for 5 minutes
INIT: Id "smar" respawning too fast: disabled for 5 minutes
INIT: Id "ligh" respawning too fast: disabled for 5 minutes
INIT: Id "weat" respawning too fast: disabled for 5 minutes
INIT: Id "rrdr" respawning too fast: disabled for 5 minutes
INIT: Id "scsy" respawning too fast: disabled for 5 minutes
INIT: Id "pwru" respawning too fast: disabled for 5 minutes
INIT: Id "user" respawning too fast: disabled for 5 minutes
INIT: Id "watc" respawning too fast: disabled for 5 minutes
INIT: Id "ther" respawning too fast: disabled for 5 minutes
INIT: Id "bxtp" respawning too fast: disabled for 5 minutes
Do I need to follow the revive tutorial or is there a workaround?
Looks like a partly corrupted root filesystem. The kernel boots, the root process (init) runs, opkg seems OK.
Can you cd to the root directory and post the (tree.txt) file generated by the following command:
ls -R > tree.txt
(please put it in an attachment, it's quite a big file, not to be put inside a post).
shelbyZ
Post by shelbyZ »
Even tough the iptables was empty I've put in the ssh line and the partly installed dropbear seems to work.
with SCP I managed to download the tree.txt as attached.
tree.rar
tree
(35.17 KiB) Downloaded 568 times
shelbyZ
Post by shelbyZ »
UPDATE:
I've run the update script again and it worked, Toon boots normal!
Let the tweaking begin
Marijn
Post by Marijn »
I succesfully rooted toon, I changed <wizardDone> to 1. Now I have a almost blank home screen. Just the clock and two greyed out buttons (home and menu), even the thermostat function is not available. How can the temp and other stuff made visible?
Two questions up front:
What happens when you set <wizardDone> back to 0?
What firmware version is your toon?
Marijn
Post by Marijn »
nothing happens when I change <wizardDone> back to 0.
My firmware version is 3.6.3
When I change <wizardDone> to 0 and /HCBv2/config/config_flash_gui.xml <disabled> back to 0 I see the activation wizard again.
Return to “Toon Rooting”
