Ha yes
D2d recording. Not sure. Where do I find that?
Around 20% CPU. 5% for BlueIris. CPU rise if I use the web interface.
30-35 degrees Celsius now. I never experienced it too hot to touch. However, I am not sure it was ever really busy.
I7 5500U low footprint server
- Member
Re: I7 5500U low footprint server
Direct to disc recording, sorry for the short cut name.
Not sure out of my head now where to find it but you can set it per cam I believe at recording tab on the bottom.
This will take away the overlay time stamp from bi.
But most cams have there own stamp so. It's not necessary.
This also lowers the cpu usage allot.
I wonder how it will. Behave when using 25mp in total at 10fps.
But thanks for the reply!
I use Direct to disc.
My Cams are 1 and 3mp.
I fiddled a lot with fps on my old atom server, you get a lot on the CPU usage when lowering fps. I never raised it from 10fps on the new server. It's good enough there.
How many MP are your cams ?
??mhn wrote: My Cams are 1 and 3mp.
