Toon apps: feature requests
Re: Toon apps: feature requests
Postby marcelr » Sun Oct 15, 2017 7:09 pm
Yes, see e.g., ToonstoreApp.qml for a set of examples.
Midnight commander
Postby gielie » Thu Nov 09, 2017 5:26 pm
Is there someone who is using midnight commander to look up files and edit them whiten mc
EDIT: moved to feature request. marcelr
gielie
Re: Rooting Toon (or boxx)
Postby marcelr » Thu Nov 09, 2017 5:46 pm
Not sure what you mean.
I use Filezilla to connect to Toon, and then edit stuff with emacs, within Filezilla, and always keep a shell open to see what's going on.
Postby gielie » Thu Nov 09, 2017 7:34 pm
Mc is a filebrowser who can run in the command shell, so I want to install mc on Toon
gielie
Re: Midnight commander
Postby marcelr » Thu Nov 09, 2017 7:42 pm
Is a recipe for it available for openembedded?
Edit: Never mind, found one. Will give it a shot.
... and ready for testing (not exactly bleeding edge, but hey, none of toon's software is ...).
(not available from the ToonStore, I don't think it's an application many people require).
These are the files you need:
http://files.domoticaforum.eu/uploads/T ... .0_qb2.ipk
http://files.domoticaforum.eu/uploads/T ... 16_qb2.ipk
Just yell if something's missing.
And remember: These packages haven't been tested. So if it doesn't work like you expect it to, it wasn't me ;-).
Postby gielie » Sat Nov 11, 2017 6:00 pm
Thanks for the MC but it didnt work
eneco-001-003065:~# opkg install mc_4.7.5-r6.0_qb2.ipk
Installing mc (4.7.5-r6.0) to root...
mc: unsatisfied recommendation for mc-extfs
mc: unsatisfied recommendation for mc-hilite
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for mc:
*      ncurses-libncursesw (>= 5.7+20110115) *         glib-2.0 (>= 2.28.0) *
* opkg_install_cmd: Cannot install package mc.
Il keep with filezilla to browse files and adjust them
gielie
Postby marcelr » Sat Nov 11, 2017 6:21 pm
Did you install the dependency first (ncurses-libncursesw)?
Postby gielie » Sat Nov 11, 2017 9:53 pm
marcelr wrote:Did you install the dependency first (ncurses-libncursesw)?
No I didn’t, I don’t want to install too much junk on the Toon, it’s already slowing down with the apps I have now.
gielie
Postby marcelr » Sat Nov 11, 2017 10:30 pm
Dependencies are parts of software that are required to make others run.
If you don't want to install them, then the code that depends on them won't work, and won't even install ...
Postby gielie » Sun Nov 12, 2017 6:15 pm
ONe other question, dont know if this is the right tread.
Id like to change the startup logo, i found in the folder themes loadscreen_0 and _1 but there is a third logo, the first one, where can i find this one? So Loadscreen_0 is the second logo and _1 is the third.
gielie
Postby marcelr » Sun Nov 12, 2017 6:48 pm
loadscreen_0.png is the third.
The first resides in flash (/dev/mtd 1 or /dev/mtd2, don't remember which one, now)
The second is a framebuffer image and resides in /usr/share/images/image-nl-bootsplash.bmp.gz
Third, the qt-gui loads loadscreen_0.png, and loadscreen_1.png comes fourth.
Re: Toon app: feature requests
Postby Hypermobile » Sun Jan 14, 2018 5:32 pm
I Checked the Forum, but i didn't find what i was looking for.
RSS-Feed app for Toon.
https://www.nu.nl/rss/Algemeen
is that something to put on a Wishlist?
Hypermobile
Postby balans » Sun Jan 14, 2018 9:47 pm
+1 on that one for me, check the weather ,traffic and the News 8)
balans
Postby Toonz » Sun Jan 14, 2018 9:58 pm
The Qt Quick documentation contains a sample rss reader in qml doc.qt.io/qt-5/qtquick-demos-rssnews-ex ... ample.html.
Might implement this on Toon at some point (when I have time available), if others feel inspired please do so. :)
Postby michel30 » Sun Jan 14, 2018 10:15 pm
I think I need to get a second Toon to do tryouts.
It sued be nice if you could clone the Toon in an vmware and play with it.
michel30
PreviousNext
Return to Toon Apps
