The new box is running but i`m having some issues with COM Ports. The COM Ports are all there but some of them are unavailable for HomeSeer.
- Zwave UZB seems to be working (lights and moution sensing is fine)
- Plugise (Source software can`t seem to find the plugwise stick)
- CaddX alarm panel is unable to connect (COM12 does not exist)
RFXCOM Error: 35 (CheckTransceivers) error :Error while connecting transceiver on COM9 ,
RFXCOM Error: 35 (InitTRX) Transceiver #1 port not open: COM9
RFXCOM Warning: 35 (Open) error :System.IO.IOException: The port 'COM9' does not exist. at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str) at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace) at System.IO.Ports.SerialPort.Open() at HSPI_RFXCOM.clsRS232.Open()
