Toon app: Dashticz (no longer working)
ronalddehaan
Re: Toon app: Dashticz (for Toon); NEW: OV Info (NL)
Post by ronalddehaan »
michel30 wrote:So you download the file as one zip file? dashticz_toon-master.zip
When you extract the zip file you will see an map like this: dashticz_toon-master
I renamed this map in dashticz and upload it in Toon , maybe you need to check the rights
What is in your dashticz folder? do you see the config etc. files directly or only 1 folder?
michel30
Post by michel30 »
[img]
[/img]
ronalddehaan
michel30 wrote:[img]
[/img]
I have the same.. don't know why the lightbulb won't show up :(
Verstuurd vanaf mijn Lenovo P2a42 met Tapatalk
Does the console output give you error messages during startup?
michel30
Post by michel30 »
The litle bulb will show on the top right from your toon it is not an table that mistake did I
ronalddehaan
Toonz wrote:Does the console output give you error messages during startup?
I don't know honestly, I have the thing mounted on the wall and access it via telnet when I need to. Hooking up the serial cable isn't something I'd do normally :roll:
ronalddehaan
michel30 wrote:The litle bulb will show on the top right from your toon it is not an table that mistake did I
I know, it's a notification bar icon, not (yet) a tile in the mainscreen. But it's not there.
One thing i do wonder, although when i think of it it doesn't seem logical, do i need to have dashticz running on my domoticz server as well?
Probably not, because you connect to the domoticz webserver ... whén the lightbulb is showing..
sanderjohan
Post by sanderjohan »
I have it working and it looks great. But what I see now is that after about every 10 seconds the screen becomes inactive due to reloading the switches. Can this refreshing/reloading being changed in a setting?
EastXIII
Post by EastXIII »
As a fan of Dashticz I was very pleased to see Dashticz on my Toon! Especially since this means that my in-laws don't have to app me anymore when babysitting: "We are in the dark, could you please turn on the lights?" (I'm still searching for a dedicated tablet and a neat and clean way to mount this)
I would really like to use the switches in the Tile on the 'homescreen'. Unfortunately, I can not get this to work. Dashticz.settings is properly edited like mentioned in posts above/earlier.
Like I said in another thread: I do not have enough experience and knowledge about coding and Toon to fix this myself. I'm trying but I still need help.
So with a little bit hesitation, because I don't like to leech, but can someone help me out?
qwerk
Post by qwerk »
did someone solved the "not starting" issue.
I can't get dashticz to start.
I checked the rights, tried it also with chmod +x *
directory is lowercase, in Globals I used lowercase.
I edited dashticz.settings
no lightbulb......
please advice
qwerk
Post by qwerk »
same problem here.
upper/lower case is checked
dashticz.settings checked
Globals.qml checked
file rights checked
other apps work fine.
please advice
Post by TheHogNL »
Which firmware on the Toon are you using?
Just manually installed dashticz on a toon1 with 4.19.10, works just fine.
Put the files in the directory /qmf/qml/apps/dashticz and it should load. No need to edit globals.qml anymore from firmware 4.16 and up (you even can't, the file is hidden in the resource files)
For the one who is maintaining the app, I created a pull request on your github as there is a minor load saved settings issue (I saw you used the same routing I am using in easyenergy app and discovered that issue yesterday). The modified version is also on my github: https://github.com/IgorYbema/dashticz_toon
hansgrave
Post by hansgrave »
I have noticed that the OV info no longer works? At first everything did well.
Homey, rooted Toon 1 and HomeAssistent.
ArieKanarie
Post by ArieKanarie »
for those who can't get it to work some things I encountered:
- when you unzip the zip file from GitHub to a folder named dashticz, make sure that you unzip the contents of the folder `dashticz-master' directly. In my case I unzipped it to the folder dashticz, and in that folder was a folder dashticz-master, and there are the real files. So short: the path should be qml/apps/dashticz/{all the dashticz files} .
After this, I got the light bulb.
-Now dashticz was stuck at "loading devices", no matter I used manual settings file or the regular settings. Only when I entered the "TileIDX" parameter (just random one of my devices) all the devices were loaded. Although I still don't now what this setting is for?
I hope this helps someone.
ArieKanarie
Now that Dashticz is working Toon becomes unresponsive most of the times.
When I get to the dashticz screen it shows most of the times "loading switches"
Locked
