Until this week and i will use this topic to describe the steps i have taken to get things going.
At first i needed to get the data out of HS3 into something i could use on other platforms. Since many of the domotica software is now talking MQTT (in some sort of way) i first installed an MQTT Broker
Installing an MQTT broker on a Ubuntu 14.04 LTS server
sudo add-apt-repository ppa:mosquitto-dev/mosquitto-ppa
apt-get install mosquitto mosquitto-clients python-mosquitto
And made some changes to /etc/mosquitto/conf.d/local.conf
Now to get the data onto the broker i installed the MQTT Plugin created by Geert-Jan and configured it to send some sensor data to the broker we just installed on the Ubuntu Server
Since there is data available on the broker we need to get it out to something usable. I planned to use cacti for this and i found a python script created by JPMens called MQTTwarn the export to cacti failed because my input file could only hold one value but MQTTwarn is updating the file with each value on a new line in the file so i have suspended the log to file project for the moment. But taking another look in the features of MQTTwarn i found out that it is also capable of sending "carbon" output and although i heard that name before it took me a day to realize that it was used by Graphite as an input source
Send the MQTT data to carbon
[defaults]
hostname = '192.168.1.200'
port = 1883
; name the service providers you will be using.
launch = file, log, carbon
[config:file]
append_newline = True
targets = {
'f01' : ['/tmp/f.01'],
'douchet' : ['/etc/snmp/douchet.txt'],
'douchev' : ['/etc/snmp/douchev.txt'],
'kantoort' : ['/etc/snmp/kantoort.txt'],
'kantoorv' : ['/etc/snmp/kantoorv.txt'],
'slaapkamert' : ['/etc/snmp/slaapkamert.txt'],
'slaapkamerv' : ['/etc/snmp/slaapkamerv.txt'],
'woonkamert' : ['/etc/snmp/woonkamert.txt'],
'woonkamerv' : ['/etc/snmp/woonkamerv.txt'],
'buitent' : ['/etc/snmp/buitent.txt'],
'buitenv' : ['/etc/snmp/buitenv.txt'],
'mqttwarn' : ['/tmp/mqttwarn.err'],
[config:log]
targets = {
'info' : [ 'info' ]
[config:carbon]
targets = {
'c1' : [ '192.168.1.198',2003 ],
topic = #
targets = file:f01
[/homeseer/398/value]
topic = /homeseer/398/value
targets = file:douchet,carbon:c1
[/homeseer/400/value]
topic = /homeseer/400/value
targets = file:douchev,carbon:c1
[/homeseer/402/value]
topic = /homeseer/402/value
targets = file:kantoort,carbon:c1
[/homeseer/403/value]
topic = /homeseer/403/value
targets = file:kantoorv,carbon:c1
[/homeseer/405/value]
topic = /homeseer/405/value
targets = file:slaapkamert,carbon:c1
[/homeseer/409/value]
topic = /homeseer/409/value
targets = file:slaapkamerv,carbon:c1
[/homeseer/413/value]
topic = /homeseer/413/value
targets = file:woonkamert,carbon:c1
[/homeseer/415/value]
topic = /homeseer/415/value
targets = file:woonkamerv,carbon:c1
targets = file:buitent,carbon:c1
[/homeseer/397/value]
topic = /homeseer/397/value
targets = file:buitenv,carbon:c1
[/homeseer/#]
topic = /homeseer/#
targets = carbon:c1
![Very Happy :D](./images/smilies/icon_biggrin.gif)
The Grafite / Grafana Part
This is a little teaser to show the potential of Grafana
![Image](http://files.raqxs.nl/domotica/Grafana_Overzicht.png)
And here is a little how to install Graphite / Grafana
Note: I will update this topic as soon as i have some historical data and a second install run
