Status bar for Plugwise circles not updating
Jeroen Bartels
Post by Jeroen Bartels »
I reccently upgraded to HS3 and stretch 2.0.
I use HStouch on android for home control and found out that switching works fine but the statusbar does not update.
I'm aware that statusbar can take some time because the refresh of power consumption is not instant.
Does anybody know the solution, has the same problem or does not have the problem?
The statusbar (red/green) below a button is crucial to know if a device is on or off.
Kind regards,
Jeroen
**Jeroen**
Akatar
Re: Status bar for Plugwise circles not updating
Post by Akatar »
if you "touch"the status bar, does it update?
i have the same problem with the p1 meter, every value on hstouch updates, execpt for the realtime usage. this one i have to "touch" to get an update.
Return to “Plugwise Forum”
