OV information app
atlantica
OV information app
Post by atlantica »
1.) First get the station id from http://api.9292.nl/0.1/locations?lang=nl-NL&q=eindhoven (Change eindhoven to your own search parameter).
2.) Copy the ID and enter this value in the 'Station / Halte' field under settings
Update:
Refresh button is now working
ovinformationapp.zip
(26.88 KiB) Downloaded 572 times
Regards
David
Re: OV information app
Hi good to see new apps, just a question, to what extent does this differ from the OV info in this app:
viewtopic.php?f=99&t=11882&p=84325&hilit=Halte#p84325
atlantica
Post by atlantica »
Toonz wrote:Hi good to see new apps, just a question, to what extent does this differ from the OV info in this app:
Hi Toonz,
That app makes your toon very slow...
Regards
David
atlantica wrote: That app makes your toon very slow...
Ok, makes sense. Will give it a try :)
Is it finished from your point of view, in other words, do you want it to be included in the ToonStore?
atlantica
Post by atlantica »
Toonz wrote:Is it finished from your point of view, in other words, do you want it to be included in the ToonStore?
Maybe a bit later. The refresh button is not working right now. But when you open de app again from the main menu it is refreching the data...
Regards
David
atlantica
Post by atlantica »
When trying fixing the old ov app url for a new one,
Old url:
xmlhttp.open("GET", "http://dashticz.nl/ov/ov.php?station="+settings.ovHalte, true);
I discovered the used source ov url:
http://api.9292.nl/0.1/locations/[ovHal ... lang=nl-NL"
#[ovHalte] = is described in this example:
Does anyone know what was in the old ov.php or
is it posible to translate this into the ov app?
Regards
David
Xavier
Post by Xavier »
Trying to get this to work but no luck, keeps trying to load data.
The links provided by Atlantica provide all info you need (seems proper JSON data to me)
However, you will need to rewrite the app to work from the 9292 site directly without the dashtics site inbetween.
I might do this when I have time, but if other feels inspired to work on this even better :-)
Xavier
Post by Xavier »
Toonz wrote:The links provided by Atlantica provide all info you need (seems proper JSON data to me)
Hi Toonz,
got any luck and time about updating this app for Firmware 5.0.4 and the rewrite directly to 9292 site?
Would like to do this but I don't have the knowdledge :(
Not yet started, will post it here when done.
small teaser, the basics are running again.
Need much more work to simplify the app structure and further enhance it.
The app will not slowdown your toon anymore.
Not sure when it's ready for release....
Templar
Post by Templar »
Toonz wrote: .... and further enhance it.
While you're at it: perhaps rename "Bushalte informatie" to "<stopType> or <stationType> informatie" en display its <name>.
Halte name is already in the WIP version :-).
I also rebuild the config screen to be able to search for a busstop from there. No need to find the busstop id yourself.
Also rebuilt the tile to show the data of the first bus departing.
To do: somehow split/sort the list of departing busses by direction. Useful if the busstop is on both sides of the road
Keep the suggestions coming....
Xavier
Post by Xavier »
great Job!
looking forward to this app.
Will it be possible that the app will show the information in a tile? like the first possible travel option?
Maybe also an idea to add 2 travel option like train and bus so that a (dis)connection is also viseble. In case the train is delayed you can take a bus later.
