turn off zelflerend
turn off zelflerend
good evening
Has someone take a look in the thermostat section.
for a possibility to turn on or off self-learning.
i do not need the self learning and would prefer only on or off at the selected time.
gr.
gr.
- Member
Re: turn off zelflerend
Modulating CV = At say (Programmable by default) 6:00 o'clock it needs to be 21.5 degrees. So the CV start heating before so that it's 21.5 at 6:00
Non-modulating / Non-Opentherm mode. (On-Off in the settings screen, It's under Heating (Verwarming)
At say (Programmable by default) 6:00 o'clock the CV starts heating untill 21.5 is reached. Then turns off. So it's not 21.5 at 6:00 0'çlock but later.
Is that what you mean?
(At say (Programmable by default) 6:00 o'clock the CV starts heating untill 21.5 is reached. Then turns off. So it's not 21.5 at 6:00 0'çlock but later.
Is that what you mean?)
yes, heating starts at the programmed time and not 1 hour or less before ( Honeywell chronotherm4 does has that possibsibillity)
If i understand the question it has nothing to do with the way the boiler gets its commands (on/off or modulation)
Some people want the heating to start at say 9:00 (the time that the room meets the required temp is unknown) other people want the heating reach the required temp at 9:00 (with an unkown start time)
I really wouldn't know why anyone would want the first scenario?! But anyhow, i don't know of any settings/changed one could do to achieve this.
The thermostat configuration has a parameter that sets maximum warm-up time. It's set to 180 minutes, IIRC. Possibly, you can set that to a much lower value to prevent toon from starting to heat early.
isiepel; the themostat can also used for elektric floor heatin or a pellet stove, ect. then you do not need zelflerend and modulation.
marcelr: thanks this is the solution. i only need a max 15 min. can you tell me where the parameters are located. I looked at it but could not find it.
thank You
thank You
It's in the project file:
/HCBv2/config/hcb_project.xml
or
/qmf/etc/qmf_project.xml
depending on your firmware version.
look for
<maxPreheatTime>180</maxPreheatTime>
(it's in minutes, IIRC). I guess that you can just change this according to your needs, and restart.
Haven't tested it myself ...
or
look for
successful, test it and works perfectly thanks
you're welcome
after update: the qmf_project.xml isn't used anymore??? i can only find a backup file.
my preheat is set back to 180 min. again
has any one an idee where to find the maxpreheat again.
gr.
gr.
you can find the setting here since a few releases: /HCBv2/etc/qmf_release.xmlDemif wrote:after update: the qmf_project.xml isn't used anymore??? i can only find a backup file.
gr.
found it,
thnx
gr.
thnx
gr.
