Controlling Toon via Pimatic
debans
Post by debans »
Hello all, i'm new the the domoticaforum, but reading for a while.
Recently i own a Toon, and have rooted it.
I use Pimatic to for home automation https://pimatic.org/
And wanted to control the Toon.
So i used the manual to Controlling Toon via Domoticz to create the manual for Controlling Toon via Pimatic
Re: Controlling Toon via Pimatic
Post by TheHogNL »
NIce to see a new user adding the Toon to a new home automation platform! Please share the details and the manual.
debans
Post by debans »
Step 1:
You need to install the following plugins to Pimatic:
  • Cron
  • log-reader
  • shell-execute
Step 2:
To get the actual information from the Toon every minute.
You can change the frequency of crawling the information.
Add the next code to the Rules section:
      "id": "toongetthermostatinfo",
      "name": "ToongetThermostatInfo",
      "rule": "when every 1 minute then execute \"curl -s 'http://192.168.1.111/happ_thermstat?action=getThermostatInfo' | jq '.' > /home/pi/pimatic-app/ToonThermostatInfo\"",
      "active": true,
      "logging": false
Step 3:
Create a LogWatcher divice to get the data from the logfile
To create a LogWatcher device getting and converting the data from the logfile, created by the rule.
Add the next code to the Devices section:
      "id": "toonthermostatinfo",
      "name": "ToonThermostatInfo",
      "class": "LogWatcher",
      "file": "/home/pi/pimatic-app/ToonThermostatInfo",
      "attributes": [
          "name": "currentTemp",
          "type": "number"
          "name": "currentSetpoint",
          "type": "number"
          "name": "programState",
          "type": "string"
          "name": "activeState",
          "type": "string"
          "name": "nextProgram",
          "type": "number"
          "name": "nextState",
          "type": "number"
          "name": "nextTime",
          "type": "number"
          "name": "nextSetpoint",
          "type": "number"
      "lines": [
          "match": ".currentTemp.:..(.+)..",
          "currentTemp": "$1:100"
          "match": ".currentSetpoint.:..(.+)..",
          "currentSetpoint": "$1:100"
          "match": ".programState.:..0..",
          "programState": "Off"
          "match": ".programState.:..1..",
          "programState": "On"
          "match": ".programState.:..2..",
          "programState": "Temporary"
          "match": ".programState.:..4..",
          "programState": "Holiday"
          "match": ".activeState.:..-1..",
          "activeState": "Manual"
          "match": ".activeState.:..0..",
          "activeState": "Comfort"
          "match": ".activeState.:..1..",
          "activeState": "Home"
          "match": ".activeState.:..2..",
          "activeState": "Sleep"
          "match": ".activeState.:..3..",
          "activeState": "Away"
          "match": ".activeState.:..4..",
          "activeState": "Holiday"
          "match": ".nextProgram.:..(.+)..",
          "nextProgram": "$1"
          "match": ".nextState.:..(.+)..",
          "nextState": "$1"
          "match": ".nextTime.:..(.+)..",
          "nextTime": "$1"
          "match": ".nextSetpoint.:..(.+)..",
          "nextSetpoint": "$1"
      "xAttributeOptions": []
Step 4:
Create 2 Variable Devices tho show the statuses
To show the actual temperature and the setpoint temperature
      "id": "toontemp",
      "name": "Toon",
      "class": "VariablesDevice",
      "variables": [
          "name": "temperature",
          "expression": "round($toonthermostatinfo.currentTemp / 100,1)",
          "type": "number",
          "unit": "°C",
          "acronym": "Temp"
          "name": "setpoint",
          "expression": "round($toonthermostatinfo.currentSetpoint / 100,1)",
          "type": "number",
          "unit": "°C",
          "acronym": "Setpoint"
To show the actual status of the active scheme and the program
      "id": "toonschemeinfo",
      "name": "Toon",
      "variables": [
          "name": "state",
          "expression": "$toonthermostatinfo.activeState",
          "label": "Scheme",
          "acronym": "Schema"
          "name": "program",
          "expression": "$toonthermostatinfo.programState",
          "label": "Program",
          "acronym": "Program"
Step 5:
Create 2 Button Devices tho toggle the program and the schemes
To create a button device for turning the auto program on or off.
      "id": "toonprogram",
      "name": "Toon Program",
      "class": "ShellButtons",
      "buttons": [
          "id": "on",
          "text": "On",
          "onPress": "curl -s 'http://192.168.1.111/happ_thermstat?action=changeSchemeState&state=1'"
          "id": "off",
          "text": "Off",
          "onPress": "curl -s 'http://192.168.1.111/happ_thermstat?action=changeSchemeState&state=0'"
To create a button device for the 4 different schemes.
      "id": "toonscheme",
      "name": "Toon",
      "buttons": [
          "id": "SetAway",
          "text": "Away",
          "onPress": "curl -s 'http://192.168.1.111/happ_thermstat?action=changeSchemeState&state=2&temperatureState=3'"
          "id": "SetSleep",
          "text": "Sleep",
          "onPress": "curl -s 'http://192.168.1.111/happ_thermstat?action=changeSchemeState&state=2&temperatureState=2'"
          "id": "SetHome",
          "text": "Home",
          "onPress": "curl -s 'http://192.168.1.111/happ_thermstat?action=changeSchemeState&state=2&temperatureState=1'"
          "id": "SetComfort",
          "text": "Comfort",
          "onPress": "curl -s 'http://192.168.1.111/happ_thermstat?action=changeSchemeState&state=2&temperatureState=0'"
Done
You now have a fully working Toon with Pimatic.
djmvt
Post by djmvt »
I've installed a Toon thermostat yesterday and in all my enthusiasm started to put your code in my config.json on pimatic, tried it, got a lot of errors and finally realised I've completely ignored the part where you wrote you rooted your Toon hahaha
But since I want to use Google home speech control with toon rooting is not an option for now, as far as I've seen.
Thanks anyway, I'll save the config.json just in case I want to root the Toon in the future!
TerrorSource
Post by TerrorSource »
djmvt wrote:I've installed a Toon thermostat yesterday and in all my enthusiasm started to put your code in my config.json on pimatic, tried it, got a lot of errors and finally realised I've completely ignored the part where you wrote you rooted your Toon hahaha
Why isn't rooting an option? After rooting, the Toon is more compatible with Domotica systems then a non-rooted Toon.
djmvt
Post by djmvt »
TerrorSource wrote: Why isn't rooting an option? After rooting, the Toon is more compatible with Domotica systems then a non-rooted Toon.
Because I will have to figure out how to keep speech control with Google home on a rooted toon. Haven't found any links about that yet but when I do find them I will probably root it :)
djmvt
Post by djmvt »
I've finally got the time to root my toon thermostat.
Now i'm trying to integrate it in pimatic but the rule
"rule": "when every 1 minute then execute \"curl -s 'http://192.168.1.111/happ_thermstat?act ... mostatInfo' | jq '.' > /home/pi/pimatic-app/ToonThermostatInfo\"",
"active": true,
"logging": false
is not working for some reason. I guess it has something to do with how the curl command is executed (placement of brackets and such) but I can't seem to figure it out. any ideas?
djmvt
Post by djmvt »
Nevermind, got it figured out!
Now to make a buttons device to set manual temperature :)
