al30k wrote:hello
do you know what can be wrong? my powermax complete only shows current status of panel(disarm, delay,armed...) (with some lags) but doestn show any other information (panel info, zones etc.) and doesn't react on pressing arm or disarm in windows app.
thanks
Did you configure the settings? So correct pincode and download code? After changing these, try restarting the application and go back to settings to check the enrolled zones
That is indeed how it should be configured. maybe u can send the config file so I can check, or can test if the application send an email upon alarm detection I use it in exactly the same way. Maybe can you also provide the logfile when initiating an alarm.
I have setup this program past week into my domoticz system (same system as where domoticz is running).
Everything is working smooth, except when I’m going out of the remote desktop environment it looks that the program is freeze because it’s not interact with Domoticz anymore.
I've been using your software for quite a while with HS3 and it happily reports status changes from the Visonic app to HS3, but as yet, I haven't been able to ARM/DISARM the panel from HS3 (or even just a UDP call) I am able to arm/disarm the panel from the software, but I can't make a call to make it happen. I'm attaching my current configuration and my event log.
This is the call I'm making on my mac to initiate the UDP call: echo ARMHOME_1234 | nc -w1 -u ha-lenovo 800
The software version is 1.2.10.149
Do you have any suggestions on what I should be doing differently?
As an aside, I haven't been able to get the http server to work at all, even with the firewall entirely turned off.
Thanks for your help!
Cheers,
Duane
Event Log
Screen Shot 2019-07-31 at 12.39.55 AM.png (279.23 KiB) Viewed 19130 times
configuration
Screen Shot 2019-07-31 at 12.37.56 AM.png (199.63 KiB) Viewed 19130 times
next to that i think the message in the log says it comes in at a dirfferent port no. which indicated its not being handled.
The webinterface should work as expected? do you get any errors? when starting up? Can you navigate to the json or xml status page? Make sure the labview runtime is not blocked in the firewall indeed.
Hi Bart, I get the attached issue after installing the application after a hard drive crash. I use windows 10 and the app always worked well. Any ideas how to fix?
