rbak wrote:I recently installed home assistant and downloaded this app from the toon store. Unfortunately I am unable to login to my Home Assistant as I do not know which default user it tries to login with. In the setup page it only asks for the password.
The version available on the Toon store does not yet include the new authorization system used by newer Home Assistant versions. On newer versions of Home Assistant we must now gain access by a Long Lived Access Token. On Github I have been working on a new version that you can try out. I still need to update the manual a bit as you need to manually add the token to the token.txt on your Toon.
https://github.com/Luc-S/Toon-HASSI also added new debug messages which you can enable by setting the 'debug' parameter to 1 in file 'HomeassistantApp.qml' (line 10). This provides you more info about what's going on in the Toon app.
Hussar_303 wrote:I've ran into the same issue as rbak... I've been running it on a Raspberry Pi so far, but I'm lost with the Android app.
I'm not sure what you mean by this, you are running Home Assistant on a Raspberry Pi, that's ok, me too
And what Android app, the app I can try to help you with is the Toon app only
