Fully automated rooting script
whizzz63
Re: Fully automated rooting script
Post by whizzz63 »
TheHogNL wrote:
whizzz63 wrote:Just to check: Tx is on pin 13? (and is Rx on de USB to Serial converter)
What else can I check?
Correct. But are you pointing to the correct pin 13? And ofcourse are you sure you have the correct password in your copy/paste buffer?
Pin 1 is on the top left, Pin 2 on the top right, pin 3 under Pin 1 and so on?
Post by TheHogNL »
Correct. So the pins you need are the last two on the bottom and the one row above on the left side.
whizzz63
Post by whizzz63 »
TheHogNL wrote:Correct. So the pins you need are the last two on the bottom and the one row above on the left side.
Seems everything is connected correctly, the password is correct (corresponding to the software version), but still...... keeps booting after pasting the password...... :cry:
Post by TheHogNL »
Just to be sure, can you post a photo of your wires connected to the toon? And the boot screen where the boot version is shown?
whizzz63
Post by whizzz63 »
TheHogNL wrote:Just to be sure, can you post a photo of your wires connected to the toon? And the boot screen where the boot version is shown?
Schermafbeelding 2019-03-09 om 10.01.53.png (54.88 KiB) Viewed 9267 times
whizzz63
Post by whizzz63 »
Post by TheHogNL »
You are connected to the correct pins. However, I was not expecting two extra wires. Most TTL adapters have 4 wires (tx, rx, gnd and 3.3v). What ttl adapter are you using and are you sure those are the tx and rx from the adapter?
mAiden
Post by mAiden »
It looks you have a PL2303, most of time this one is 5v
You need 3v3.
Try at you're own risk this one:
Black wire is GND, connect this one on GnD from Toon.
Green wire is TXD, connect this one on RxD from Toon.
White wire is RxD, connect this one on TxD from Toon.
Can you put the password now in?
whizzz63
Post by whizzz63 »
TheHogNL wrote:You are connected to the correct pins. However, I was not expecting two extra wires. Most TTL adapters have 4 wires (tx, rx, gnd and 3.3v). What ttl adapter are you using and are you sure those are the tx and rx from the adapter?
It is a USB to TTL converter with a FTDI chipset.
6 wires:
1. Yellow: RTS
2. Black: GND
3. Blue: CTS
4. Green: TXD
5. Red: 5v
6. White: RXD
whizzz63
Post by whizzz63 »
mAiden wrote:It looks you have a PL2303, most of time this one is 5v
You need 3v3.
No, unfortunately, I can't put the password in.....
Post by TheHogNL »
Where did you buy this? Are you sure it is 3.3v (as the red power is putting 5v my guess is that your TX is also on 5V)?
whizzz63
Post by whizzz63 »
TheHogNL wrote:Where did you buy this? Are you sure it is 3.3v (as the red power is putting 5v my guess is that your TX is also on 5V)?
This one is from AliExpress.
Wich one do you suggest?
Post by TheHogNL »
By the way, you are posting this in the automated rooting script topic... you are using the manual way. :-) My guess is that your cable is wrong, or now with 5v you might have broken the UART on the toon (requering 3.3v).
paul89
Post by paul89 »
Rooted my Toon a couple of weeks ago and just wanted to say the automated script is awesome.
I only had some issues with installing OpenOCD on the Raspberry Pi though, I ended up installing it the way described here, after that, it worked as a charm!
Plumifrons
Post by Plumifrons »
What is 'best practice' for using the rooting script?
Should I reset my toon to factory settings before rooting or afterwards? Do I need to setup wifi before using the script (i guess not...)
Do I loose the activation by resetting it, or is that fixed again by using the stript?
Return to “Toon Rooting”
