Toon for Android
Re: Toon for Android
Postby RoadXY » Thu Apr 11, 2019 9:40 am
0.5.6 is released to Alpha.
Solved issues in this release:
https://github.com/fabianblom/Toon-Andr ... ne%3A0.5.4
Bugfix: When starting app, the correct mode button wasn't selected
Bugfix: Fix toast message when setting stuff (Fixes fabianblom#13)
Bugfix: IllegalFormatConversionException on formatting string
Bugfix: change layout so it works better on lower resolution devices (fixes fabianblom#24)
Bugfix: Next program text contained "\n" text
Bugfix: Use CurrentUsageInfo for power and gas usage instead of DeviceInfo (fixes fabianblom#8)
Bugfix: Get next set point (fixes fabianblom#6)
Enhancement: Auto refresh & pull down to refresh
Enhancement: Change layout to resemble o.g. Toon app
Enhancement: Add support for when no program is used
Enhancement: Add setting to choose between next program or next temp
Enhancement: Set power usage meter relative to average usage
Enhancement: Add extra setting to change temperature by 1 degree
Enhancement: Only 1 decimal after the comma (Solves fabianblom#14)
Enhancement: Provide feedback when using the refresh button (Solves fabianblom#15)
Enhancement: Use burner info (only on OpenTherm?) to show flame
Enhancement: Change mode buttons to resemble the Toon buttons
RoadXY
Postby glsf91 » Thu Apr 11, 2019 8:05 pm
RoadXY wrote:0.5.6 is released to Alpha.
You made good progress. My compliments. Working much better now.
glsf91
Postby MyZ » Thu Apr 11, 2019 8:19 pm
Great work!
MyZ
Postby RoadXY » Thu Apr 11, 2019 10:28 pm
Thanks guys!
Now bring them bugs all I can iron these out before the Beta users get the update.
Let's work towards an stable app so it's available for everyone.
RoadXY
Postby TerrorSource » Fri Apr 12, 2019 12:18 pm
I'm still on 0.5.2 and the Play Store doesn't show an update for me.
TerrorSource
Postby _Arjen_ » Fri Apr 12, 2019 1:11 pm
Because PlayStore is the Beta channel ;)
This version is available for the alpha testers
_Arjen_
Postby glsf91 » Fri Apr 12, 2019 3:25 pm
_Arjen_ wrote:Because PlayStore is the Beta channel ;)
Not true. I got the alpha version through playstore.
You have to register as alpha tester first. See previous messages.
glsf91
Postby _Arjen_ » Fri Apr 12, 2019 3:31 pm
Yup you're right
Just forgot that part haha
_Arjen_
Postby Toonz » Fri Apr 12, 2019 4:30 pm
I am registered as alpha tester but only get 0.5.2 from the play store
Postby marcelr » Fri Apr 12, 2019 5:01 pm
Can't see any updates either ...
Postby MyZ » Fri Apr 12, 2019 5:20 pm
Same here...
MyZ
Postby ams123 » Fri Apr 12, 2019 6:32 pm
same here
Toon solarpannels
ams123
Postby RoadXY » Fri Apr 12, 2019 8:11 pm
I've double-checked but 0.5.6 is really in Alpha.
0.5.2 is in beta
RoadXY
Postby glsf91 » Fri Apr 12, 2019 8:14 pm
I received 0.5.6 yesterday through playstore as an update.
glsf91
Postby mAiden » Fri Apr 12, 2019 8:20 pm
Ive install it yesterday from the Play Store.
mAiden
PreviousNext
Return to Toon external control
