HomeSeer HS3 Plugwise Pro 4 is released!
Postby stefxx » Tue Jun 11, 2019 6:24 am
Release 4.0.0.0 is in the HomeSeer HS3 updater and shop!
https://shop.homeseer.com/products/stef ... in-for-hs3
All details, release notes, screen shots etc can be found here: https://forums.homeseer.com/forum/3rd-p ... a-smile-p1
Documentation can be found here: http://homeseer.com/guides/plugins/Home ... %204.0.pdf
For support: https://forums.homeseer.com/forum/3rd-p ... ion/stefxx
Warning: for some users the 30-day trail expires immediately after installation. It seems to be related with the installation of beta versions, but I am not sure. So if this happens to you, there are a few options:
- Email to support at homeseer, requesting an "extra" 30 days to test, or
- Reinstall beta 3 (nearly the same version anyway) until you are satisfied and ready to buy, or
- Just buy the plugin. A license will be provided right away after purchase.
Thanks! Let me know if you run into problems or have questions.
stefxx
Re: Plugwise Pro 4 is released!
Postby Edwin2008 » Tue Jun 11, 2019 6:35 am
Good to hear. Hopefully this week time to install W10 and HS3.
** edwin **
Edwin2008
Postby Bastiaan » Tue Jun 11, 2019 5:22 pm
Nice work!
No-brainer to support you!
In my case the upgrade was a bit messy with the update showing two times but after some selections I got it working and got the 30 days but purchased immediately.
Thanks for the nice work.
Bastiaan
Bastiaan
Postby Akatar » Tue Jun 11, 2019 5:26 pm
indeed a "no brainer"
Akatar
Postby stefxx » Tue Jun 11, 2019 5:59 pm
Thanks for your support guys!
stefxx
Re: HomeSeer HS3 Plugwise Pro 4 is released!
Postby Wim2008 » Sat Dec 14, 2019 12:25 pm
I use now plugin Plugwise 3.1.0.0. Must I delete this plugin in HS3 before I like to try or use Plugwise Pro 4?
Wim
Wim2008
Postby stefxx » Sat Dec 14, 2019 12:34 pm
No, you can simply upgrade through the updater. After installation, you will be guided by an upgrade process. Make sure to backup your system if you want to be able to go back to version 3. Devices will be modified which makes them incompatible with older versions of the plugin.
stefxx
Postby Wim2008 » Sat Dec 14, 2019 3:33 pm
Thanx.
I am looking for a realtime check for my energy and gas consumption. I like to buy a Smile V3 which read directly form my P1 line.
With my circles I can see where the consumption will take place in my home.
Wim2008
Postby stefxx » Sat Dec 14, 2019 3:47 pm
Ah, I think you want to update from the old (non Pro) version? There is no upgrade path for that, and the new version 4 won't work with Source either. Sorry for the confusion.
stefxx
Postby Wim2008 » Sat Dec 14, 2019 9:54 pm
Oke no problem. Which Plugwise software must I use then, to work with the plugin of you?
Wim2008
Postby stefxx » Sat Dec 14, 2019 11:28 pm
No other software is required. The plugin communicates directly to the stick, adam, anna, stretch, smile p1 etc without additional software.
When using the stick (without stretch), the source software is needed for initial setup and configuration of the circles only. Source cannot run at the same time as the plugin. I assume your circles are setup already, so there is no need for the Source software at all anymore.
stefxx
Postby Wim2008 » Sun Dec 15, 2019 9:08 am
Thanx. I gone try it.
Wim2008
Postby Wima » Thu Jun 11, 2020 8:45 pm
Plugwise Pro update --> 4.0.0.9 does not work.
I was updating my HS3 plugins but did get an error installing Plugwise Pro. At this moment 3.0.3.2 installed.
In the upgrade manual on HS forum you mentioned prior to the 4.0.0.X version first install the lagecy version.
The lagacy version is the same as my installed version, so, already running. Any clues how to get to 4.0.0.9 ?
The error: Install/Update of package Plugwise Pro failed. Yes, I did switched of the plugin when installing.
domoticaforum.eu/viewtopic.php?f=39& ... mp;t=12818
Thanks
even the genious ask questions
Wima
Postby stefxx » Thu Jun 11, 2020 9:45 pm
What version of HS4 are you using?
When you search for Plugwise Pro in the HS4 store, this is what you see:
Annotation 2020-06-11 222528.png (33.4 KiB) Viewed 286 times
Under Legacy Plugins, the left one is the 4.0.0.9 version. The right one is the very old, free version you already have installed.
Does this help? Good luck!
stefxx
Postby Wima » Fri Jun 12, 2020 5:47 am
Hi Stef,
Thank you for your quick reply. I did reboot the system (windows10 and HS3 (version HS3 Standard Edition 3.0.0.548))
Now finaly the 4.0.0.9 is installed, but. Am I right that I did always used the free version and the new one I have to register/buy.
If so, no problem. But at this moment:
Are my previous settings stil useable?
Wima
Next
Return to Plugwise Forum
