Fully automated rooting script
Monoposto013
Re: Fully automated rooting script
Post by Monoposto013 »
Aaah, don't know what happened, but lost my chrony.conf :oops: completely empty..
What to do? Just wanted to make modifications to the timeserver.
Post by TheHogNL »
Monoposto013 wrote:Aaah, don't know what happened, but lost my chrony.conf :oops: completely empty..
In the chrony.ipk package there is a new fresh conf for you.
Just start the update-rooted.sh script with option -o (to open the VPN and setup the opkg repository for you). Then type:
opkg update
opkg remove --force-depends chrony
opkg install chrony
Monoposto013
opkg update
opkg install chrony
Worked like a charm! Thanks!!
I'm still struggling with what to do next?
Rooted the Toon using the automated script, but have seen a lot of modifications in this forum and elsewhere on the internet.
-I would like the Toon not to ping quby
-use a different timeserver
-enable all the Toon/Eneco features including Zon
-install the Toonstore
Where to start? I mean, is this all done through SSH? Are there scripts available to make these adjustments?
Any help is welcome :P
Post by TheHogNL »
Monoposto013 wrote: I'm still struggling with what to do next?
That is what the update-rooted.sh -f option is for :-)
Monoposto013
TheHogNL wrote: That is what the update-rooted.sh -f option is for :-)
POWERFUL!! Great work, hats off!! This is even better than I thought :D
Knol010
Post by Knol010 »
Ishimaru wrote:Hi,
can someone help me with this issue?
root@raspberrypi:~/ToonRooter# sudo python . --jtag-available
INFO:__main__:Starting up...
CRITICAL:__main__:Cannot autodetect jtag hardware
root@raspberrypi:~/ToonRooter# sudo python . --jtag-hardware rpi3
INFO:__main__:Written private and public key pair to ./id_rsa and ./id_rsa.pub, respectively
INFO:rooter:Waiting for Toon to restart
--- waiting forever :-) --
root@raspberrypi:~/ToonRooter# cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 4 (v7l)
BogoMIPS : 38.40
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 1
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 2
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 3
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
Hardware : BCM2835
Revision : 2a02082
Serial : 0000000003d4f64b
I have the same problem and don't no what now.
I checked the wiring 1000 times. When I try to root without the script I can change uboot and get in the root shell. I then get stuck with the internet connection...
Post by TheHogNL »
Most users forget to disable the serial console on the raspberry pi (using raspi_config). That results in the toonrooter and the serial console using the serial port at the same time.
Knol010
Post by Knol010 »
TheHogNL wrote:Most users forget to disable the serial console on the raspberry pi (using raspi_config). That results in the toonrooter and the serial console using the serial port at the same time.
Now I get this message:
pi@raspberrypi:~/ToonRooter $ sudo python . --jtag-hardware rpi3
INFO:rooter:Toon has U-Boot version 2010.09-R10
ERROR:rooter:Unable to log in using password (need JTAG, but it's disabled)
I have a JTAG and I can flash the boot loader with that, but when I done that and press the reset button in the root shell nothing happens so I can't go on from there neither.
Post by TheHogNL »
You need to add "--jtag-available" as commandline option
Knol010
Post by Knol010 »
When i only use --jtag avaiable i get:
pi@raspberrypi:~/ToonRooter $ sudo python . ---jtag-available
So i have to combine jtag avaiable and jtag hardware?
How do i do that?
Thanks
Post by TheHogNL »
How do i do that?
Thanks
I did say you needed to add the option. It is really not that hard...
sudo python . --jtag-hardware rpi3 ---jtag-available
Knol010
Post by Knol010 »
How do i do that?
Thanks
For me it is. Thanks it worked nu Toon is rooted now!
Post by TheHogNL »
Knol010 wrote: For me it is. Thanks it worked nu Toon is rooted now!
Welcome to the club ;-)
Floats
Post by Floats »
Having an issue with rooting my Toon
When I try to install openOCD :
pi@raspberrypi:~ $ bash
pi@raspberrypi:~ $ git clone --recursive git://git.code.sf.net/p/openocd/code openocd
Cloning into 'openocd'...
remote: Enumerating objects: 62985, done.
remote: Counting objects: 100% (62985/62985), done.
remote: Compressing objects: 100% (26823/26823), done.
remote: Total 62985 (delta 51779), reused 43800 (delta 35996)
Receiving objects: 100% (62985/62985), 14.22 MiB | 4.93 MiB/s, done.
Resolving deltas: 100% (51779/51779), done.
Submodule 'jimtcl' (https://repo.or.cz/jimtcl.git) registered for path 'jimtcl'
Submodule 'src/jtag/drivers/libjaylink' (https://repo.or.cz/libjaylink.git) registered for path 'src/jtag/drivers/libjaylink'
Submodule 'tools/git2cl' (https://repo.or.cz/git2cl.git) registered for path 'tools/git2cl'
Cloning into '/home/pi/openocd/jimtcl'...
remote: Counting objects: 7715, done.
remote: Total 7715 (delta 0), reused 0 (delta 0)        /s
Receiving objects: 100% (7715/7715), 6.05 MiB | 4.17 MiB/s, done.
Resolving deltas: 100% (5609/5609), done.
Cloning into '/home/pi/openocd/tools/git2cl'...
remote: Counting objects: 64, done.
remote: Total 64 (delta 0), reused 0 (delta 0)
Cloning into '/home/pi/openocd/src/jtag/drivers/libjaylink'...
remote: Counting objects: 1004, done.
remote: Total 1004 (delta 0), reused 0 (delta 0)
Receiving objects: 100% (1004/1004), 236.74 KiB | 1.94 MiB/s, done.
Resolving deltas: 100% (767/767), done.
Submodule path 'jimtcl': checked out 'a9bf5975fd0f89974d689a2d9ebd0873c8d64787'
Submodule path 'src/jtag/drivers/libjaylink': checked out 'f73ad5e667ae8b26a52b847c603fdadaabf302a6'
Submodule path 'tools/git2cl': checked out '8373c9f74993e218a08819cbcdbab3f3564bbeba'
pi@raspberrypi:~ $ cd openocd
pi@raspberrypi:~/openocd $ sudo apt install make libtool libtool-bin pkg-config autoconf automake texinfo libusb-1.0 libusb-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'libusb-1.0-0' for regex 'libusb-1.0'
Note, selecting 'libusb-1.0-0-dev' for regex 'libusb-1.0'
Note, selecting 'libusb-1.0-doc' for regex 'libusb-1.0'
libusb-1.0-0 is already the newest version (2:1.0.22-2).
libusb-1.0-0 set to manually installed.
make is already the newest version (4.2.1-1.2).
make set to manually installed.
pkg-config is already the newest version (0.29-6).
The following additional packages will be installed:
  autotools-dev libauthen-sasl-perl libdata-dump-perl libencode-locale-perl
  libfile-listing-perl libfont-afm-perl libhtml-form-perl libhtml-format-perl
  libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl
  libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl
  libhttp-message-perl libhttp-negotiate-perl libio-html-perl
  libio-socket-ssl-perl libltdl-dev liblwp-mediatypes-perl
  liblwp-protocol-https-perl libmailtools-perl libnet-http-perl
  libnet-smtp-ssl-perl libnet-ssleay-perl libsigsegv2 libtext-unidecode-perl
  libtimedate-perl libtry-tiny-perl liburi-perl libwww-perl
  libwww-robotrules-perl libxml-libxml-perl libxml-namespacesupport-perl
  libxml-parser-perl libxml-sax-base-perl libxml-sax-expat-perl
  libxml-sax-perl m4 perl-openssl-defaults tex-common
Suggested packages:
  autoconf-archive gnu-standards autoconf-doc gettext libdigest-hmac-perl
  libgssapi-perl libtool-doc libcrypt-ssleay-perl gfortran
  | fortran95-compiler gcj-jdk libauthen-ntlm-perl libxml-sax-expatxs-perl
  m4-doc debhelper texlive-base texlive-latex-base texlive-generic-recommended
  texinfo-doc-nonfree texlive-fonts-recommended
The following NEW packages will be installed:
  autoconf automake autotools-dev libauthen-sasl-perl libdata-dump-perl
  libencode-locale-perl libfile-listing-perl libfont-afm-perl
  libhtml-form-perl libhtml-format-perl libhtml-parser-perl
  libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl
  libhttp-daemon-perl libhttp-date-perl libhttp-message-perl
  libhttp-negotiate-perl libio-html-perl libio-socket-ssl-perl libltdl-dev
  liblwp-mediatypes-perl liblwp-protocol-https-perl libmailtools-perl
  libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl libsigsegv2
  libtext-unidecode-perl libtimedate-perl libtool libtool-bin libtry-tiny-perl
  liburi-perl libusb-1.0-0-dev libusb-1.0-doc libusb-dev libwww-perl
  libxml-sax-perl m4 perl-openssl-defaults tex-common texinfo
0 upgraded, 49 newly installed, 0 to remove and 0 not upgraded.
Need to get 6,711 kB of archives.
After this operation, 25.9 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Abort.
And then when I try to Root the toon :
pi@raspberrypi:~ $ sudo apt install python-serial python-cryptography
python-cryptography is already the newest version (2.6.1-3+deb10u2).
python-cryptography set to manually installed.
python-serial is already the newest version (3.4-4).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@raspberrypi:~ $ git clone https://github.com/martenjacobs/ToonRooter.git
Cloning into 'ToonRooter'...
remote: Enumerating objects: 19, done.
remote: Counting objects: 100% (19/19), done.
remote: Compressing objects: 100% (19/19), done.
remote: Total 200 (delta 7), reused 3 (delta 0), pack-reused 181
Receiving objects: 100% (200/200), 439.99 KiB | 1.30 MiB/s, done.
Resolving deltas: 100% (96/96), done.
pi@raspberrypi:~ $ cd ToonRooter
pi@raspberrypi:~/ToonRooter $ sudo python . --jtag-available
INFO:__main__:Detected JTAG hardware 'rpi3'
INFO:rooter:Loading new bootloader
INFO:rooter:Starting openocd
CRITICAL:__main__:[Errno 2] No such file or directory
pi@raspberrypi:~/ToonRooter $ --output-level DEBUG
bash: --output-level: command not found
I'm using a raspberry Pi 3 B+ with fresh installed Raspbian.
mAiden
Post by mAiden »
Floats wrote:Having an issue with rooting my Toon
Suggested packages:
Abort.
You did the install of OpenOCD wrong, look at this:
cd openocd
./bootstrap &&\
./configure --enable-sysfsgpio\
     --enable-bcm2835gpio \
     --prefix=/usr\
make -j4
} 2>&1 | tee openocd_build.log
sudo make install
Go to OpenOCD:
cd openocd
Then run the following command (Use everything what here stand!):
./bootstrap &&\
     --prefix=/usr\
make -j4
And the run this command:
sudo make install
Return to “Toon Rooting”
