Toon for Android
RoadXY
Re: Toon for Android
Post by RoadXY »
anconakip wrote:
_Arjen_ wrote:It is 10080
Nope. Sorry. The the app say to me: pagina niet gevonden op apparaat.
And if i do 10800 the iT says: geen reactie van apparaat.
Could be an issue with your Toon.
What kind of output does:
http://IP-OF-TOON:PORT-OF-TOON/happ_thermstat?action=getThermostatInfo
provide?
bjorker
Post by bjorker »
Can it be that your toon ip address has changed after the upgrade/reboot.
Happened to me once.
Sent from my moto g(6) plus using Tapatalk
mAiden
Post by mAiden »
Then enter a static ip for Toon in your router. As a result, the DHCP server will always distribute that ip.
hanplo
Post by hanplo »
Toon for Android and TSC Toon Mobiel does not give gas value, but does provide electricity. Toon himself gives gas value. Does anyone have a solution.
RoadXY
Post by RoadXY »
As Fabian isn't responding anymore I've disconnected my Github with his.
The new issue url is: https://github.com/Inversion-NL/Toon-An ... new/choose
I've updated the first post of this thread also.
estate
Post by estate »
Hi :)
As of yesterday I own me a Toon and now landed on the setting up to use it from the web.
I downloaded your app and if I connect with the internal IP (192.168.-.- range and port 80) the app works like a charm and I can control and view Toon, but..... when I enter the outside IP (the one my provider gave me) I get no connection, I tried ports 80, 10800, 10080 but nothing works.
Then I suddenly reminded that if you want to connect to something from the outside to the inside network you need to use port forwarding, at least that was the case years ago when I went to school regulairly :)
My question therefore is, do I need to port forward the Toon and which port and specifically which protocol do I use, TCP or UDP ?
Who can give me the working answer and is willing to support me on this ?
WickedMaster
Post by WickedMaster »
You indeed have to forward a port to reach your Toon from the outside. You can, for example, forward port 10080 (TCP) to your Toon.
mAiden
Post by mAiden »
Forwarding on port 80 is enough, that port is also open on iptables.
Then add you're extern IP ad the config file in the app, and set port to 80.
You can test the connection on you're mobile network (3g or 4g)
RoadXY
Post by RoadXY »
0.5.7 is released to alpha:
Added navigation drawer
Added Graphs for elec and gas
Setting for double tariff
Different icons for hot water and modulation levels
Aparte icoontjes voor warm water modulatie niveaus
m3 to litre (https://github.com/fabianblom/Toon-Android/issues/34)
Added units to refresh settings
Added 5 and 15 min (https://github.com/fabianblom/Toon-Android/issues/36)
Clicking gas or elec cards wil take you to the graphs
Bug fix: deselect program when using the + or - button
Please let me know if there are any issues.
Post by TheHogNL »
How can I get into the alpha testing?
ik zie alleen de 0.5.6 beta
RoadXY
Post by RoadXY »
TheHogNL wrote:How can I get into the alpha testing?
PM me your mail adres which is the Play Store account on your phone so I can add you to the alpha testers.
RoadXY
Post by RoadXY »
Toonz wrote:ik zie alleen de 0.5.6 beta
Currently only released for for alpha testers.
yjb
Post by yjb »
I'm on 0.5.7 but my "current gas usage" is always 0.
For GAS usage, the charts are empty "no chart data available"
The strange thing is that the total of today is displayed (and correct).
getdevices output:
"dev_3": {
"uuid": "8535fd22-4500-45bb-8852-f5c7160a5c90",
"name": "HAE_METER_v3",
"internalAddress": "3",
"type": "HAE_METER_v3",
"supportsCrc": "1",
"ccList": "5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e",
"supportedCC": "5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e",
"nodeFlags": [],
"IsConnected": "1",
"HealthValue": "10",
"DeviceName": "HAE_METER_v3",
"CurrentSensorStatus": "UNKNOWN"
"dev_3.1": {
"uuid": "d776e6d1-24e5-4b4e-8d89-2c68735489b3",
"name": "HAE_METER_v3_1",
"internalAddress": "3.1",
"type": "HAE_METER_v3_1",
"supportsCrc": "0",
"ccList": "5e 59 85 8e 3c 3d 3e",
"supportedCC": "5e 59 85 8e 3c 3d 3e",
"nodeFlags": [],
"CurrentGasFlow": "7.00",
"CurrentGasQuantity": "2115186.00",
"DeviceName": "HAE_METER_v3_1",
"CurrentSensorStatus": "OPERATIONAL"
"dev_3.2": {
"uuid": "a85b3097-3076-45bf-9ab1-7f671dc13f5b",
"name": "HAE_METER_v3_2",
"internalAddress": "3.2",
"type": "HAE_METER_v3_2",
"supportsCrc": "0",
"nodeFlags": [],
"DeviceName": "HAE_METER_v3_2",
"CurrentElectricityFlow": "NaN",
"CurrentElectricityQuantity": "NaN",
"dev_3.3": {
"uuid": "aacf62a8-80d5-4061-885a-d27d4c7c2162",
"name": "HAE_METER_v3_3",
"internalAddress": "3.3",
"type": "HAE_METER_v3_3",
"supportsCrc": "0",
"nodeFlags": [],
"DeviceName": "HAE_METER_v3_3",
"CurrentElectricityFlow": "0.00",
"CurrentElectricityQuantity": "2291014.00",
"dev_3.4": {
"uuid": "0cef5b2b-7272-4143-906f-59b284070bb4",
"name": "HAE_METER_v3_4",
"internalAddress": "3.4",
"type": "HAE_METER_v3_4",
"supportsCrc": "0",
"nodeFlags": [],
"DeviceName": "HAE_METER_v3_4",
"CurrentElectricityFlow": "460.00",
"CurrentElectricityQuantity": "1607322.00",
"dev_3.5": {
"uuid": "eb6ba2f9-558d-4944-b238-258a70115c77",
"name": "HAE_METER_v3_5",
"internalAddress": "3.5",
"type": "HAE_METER_v3_5",
"supportsCrc": "0",
"nodeFlags": [],
"DeviceName": "HAE_METER_v3_5",
"CurrentElectricityQuantity": "919657.00",
"dev_3.6": {
"uuid": "efe14178-7bdc-4d14-b1fa-32a5deaf4d6a",
"name": "HAE_METER_v3_6",
"internalAddress": "3.6",
"type": "HAE_METER_v3_6",
"supportsCrc": "0",
"nodeFlags": [],
"DeviceName": "HAE_METER_v3_6",
"CurrentElectricityQuantity": "2324772.00",
"dev_3.7": {
"uuid": "22397305-82e3-46c1-b0f0-05dbe3263f30",
"name": "HAE_METER_v3_7",
"internalAddress": "3.7",
"type": "HAE_METER_v3_7",
"supportsCrc": "0",
"nodeFlags": [],
"DeviceName": "HAE_METER_v3_7",
"CurrentElectricityQuantity": "430359.00",
"dev_3.8": {
"uuid": "e0a42332-622a-43a4-bbf7-c516ef5f8745",
"name": "HAE_METER_v3_8",
"internalAddress": "3.8",
"type": "HAE_METER_v3_8",
"supportsCrc": "0",
"nodeFlags": [],
"DeviceName": "HAE_METER_v3_8",
"CurrentHeatQuantity": "NaN",
"dev_settings_device": {
"uuid": "d6d5ce1d-2055-40f4-b9b3-991f1a8f6848",
"name": "settings_device",
"internalAddress": "settings_device",
"type": "settings_device"
RoadXY
Post by RoadXY »
I've fixed that in the upcoming version
