Toon for Android
- Starting Member
Re: Toon for Android
since recent the app doesn't work anymore for me, it says "not authorised" when refreshing?
Which version of the app?
- Starting Member
0.5.6
when I open the page in a browser, I get to see some sort of zigbee (I think?) page, with the option to connect to other devices.
Could you show an screenshot?
- Starting Member
Was already working on it, have to config portforwarding as I am at work at the moment, give me a minute.
- Starting Member
see attachment.
I think it happend after updating apps from the toon store.
- Screenshot_20191211-131935_Chrome.jpg (25.12 KiB) Viewed 9287 times
- 20191211_131900.jpg (35.9 KiB) Viewed 9287 times
This most certainly not Toon we're looking at.
I think Toon got a different IP adres and this is another device in your network.
That is the /hdrv_zwave page of the toon
Please check /qmf/etc/qmf_release.xml below hcb_web if enforcewhistlist is still on 0 (and if not change to 0 and reboot)
If I open that page on my Toon I get an error message:TheHogNL wrote:That is the /hdrv_zwave page of the toon
{"result": "error", "error":"no action in request"}
Please run update-rooted.sh with option -fArieKanarie wrote:see attachment.
or
- Starting Member
That did the trickTheHogNL wrote:Please run update-rooted.sh with option -f
Hi Y'all
Please explain this in laimens terms ?
Graag uitleg in lekentaal svp ?
Ik heb sinds enige tijd dezelfde foutmelding, ook sinds de update via de google store.
Omdat automatisch updaten op mijn gsm is ingeschakeld gebeurt zoiets natuurlijk weer mij
- Starting Member
My problem had nothing to do with an update from the app (Which is not updated recently I think) but with an update of de TOONstore.
I assume you have a rooted Toon, and therefore have ssh access to the Toon.
So just connect to the Toon with for example with Putty, and issue the command: update-rooted.sh -f
Yes, app hasn't been updated for a while.ArieKanarie wrote:My problem had nothing to do with an update from the app (Which is not updated recently I think) but with an update of de TOONstore.
