rooting issue (tx/rx connected) help
vso
Post by vso »
I am trying to root the toon,
- rpi (1b+) tx,rx gnd connected to toon
- i used screen/minicom with 115200, 8n1 to ttyAMA0
- toon U-Boot 2010.09-R8 (Dec 03 2012 - 12:50:30)
I get data only because of "reasons" i don't understand the data gets messy (data shifts or gets a ladder view) and unreadable characters ..
the RPI freezes because of this .. I cannot root..
CPU:   Freescale i.MX27 at 400.168 MHz
DRAM:  128 MiB
NAND:  128 MiB
Do i need to connect more cables ?? any advise is appriciated ..
TerrorSource
Re: rooting issue (tx/rx connected) help
Post by TerrorSource »
Why not use the ToonRooter? Makes it easier.
My guess is that your trying to root a Toon with 4.16.8+ firmware which must be done via secure line. Pretty hard if you never done that.
vso
Post by vso »
Secure line ? could you explain or give me a link what explains this a bit more ?
do i need to connect more pins ?
Post by TheHogNL »
vso wrote:I am trying to root the toon,
DRAM:  128 MiB
NAND:  128 MiB
Did you disable the Pi's normal serial console output? Probably you are now getting two sources tallking on same line.
TerrorSource
vso wrote:Secure line ? could you explain or give me a link what explains this a bit more ?
nevermind my useless previous post. was too realy and didnt thought well enough :roll:
Spoken with TheHogNL and best thing for you to do is using ToonRooter.
That will automaticallt recognize the Pi model used and adjust the JTAG for that Pi model.
vso
Post by vso »
hmmm well actually you might be right on this one :D :roll: :lol:
vso
Post by vso »
@TerrorSource You might be right,, stupid me
Post by TheHogNL »
If you had followed the toonrooter manual you would have noticed that :)
vso
Post by vso »
TheHogNL wrote: If you had followed the toonrooter manual you would have noticed that :)
if I had connected directly the JTAG pins .. instead of only tx/rx and indeed RFTM --> less headache
Return to “Toon Rooting”
