Since I like the whole project and the effort many people put into it, I started to fiddle around with making my own app/tile.
I'm trying to integrate DSMR reader (as a start, later my solar panel info) information with Toon to get it display some data. I managed to at least get the tile working and the 'App' part to retrieve data from DSMR reader.
However I'm having a hard time getting the info aligned onto a tile and debugging why variables are not populated etc. I know how to get gt to log into a logfile, but does anyone know about something like an emulator or share what dev. environment/setup they use? Because now every time I need to restart the gui to test changes and that takes at least minutes to start (Toon v1) just to discover I made a typo somewhere or that my changes didn't have the desired effect. As you can imagine, quite a frustrating procedure.
So instead of re-inventing the wheel, I thought checking here if anyone has some info about a better way to develop (and test!) apps for the Toon.
Linux tools are preferred, but I also have a windows VM so windows tools would be possible.
Hope this is the correct subforum to ask. Else feel free to move ;o)
Onno.
QT / Toon emulator? Good development environment?
- Administrator
Re: QT / Toon emulator? Good development environment?
Good to see others trying to develop apps!
We don't have any emulator unfortunately. Most of the current developers have a spare Toon2 which they use for development.
Takes less then a minute for a cold-boot. around half the time for a gui-restart.
Tnx for the quick reply TerrorSource!
Hmm, guess I have to look in the other subforum for a not-too-expensive rooted Toon2 ;o)
I'll keep an eye it. Thanks!
Any hints on usefull IDE's (and/or toolchains) or are you guys also using VI only
- Administrator
Most of us use Notepad++ or plain-Notepad.ovdleun wrote:Tnx for the quick reply TerrorSource!
i use Notepad++ for example and just try it out and keep an eye on the logs.
PM me for a rooted Toon2. Got 1 laying around with scratches so if you dont mind those
Perfect for development, not so perfect in the living room
