Toon App: DoorCam
Re: Toon App: DoorCam
Postby oepi-loepi » Tue Aug 11, 2020 10:24 pm
This is the link to the original post.
https://www.domoticaforum.eu/viewtopic. ... 324#p90536
oepi-loepi
Postby stack » Wed Aug 12, 2020 10:50 pm
oepi-loepi wrote:This is the link to the original post.
Thanks, this works right away. I'm happy
stack
Postby Xavier » Thu Aug 13, 2020 8:22 pm
Is there any change that you review the App from the Toonstore?
Toon2 with 5.33.9 firmware TSC 2.1.1
Apps: Sonos, Calender, garbagecalender, traffic information, webcam, doorcam, PostNL, public transport, Onkyo, Domoticzboard and weather app.
Xavier
Postby oepi-loepi » Fri Aug 14, 2020 11:21 am
yes i will debug the app from the toonstore but since i do not have the problems i need some input. Can you help me debugging? Do you know how to use Putty and WinSCP and do you have some basic knowledge of Linux?
oepi-loepi
Postby Xavier » Fri Aug 14, 2020 2:46 pm
oepi-loepi wrote:yes i will debug the app from the toonstore but since i do not have the problems i need some input. Can you help me debugging? Do you know how to use Putty and WinSCP and do you have some basic knowledge of Linux?
sure I can help, what would you like to know?
Xavier
Postby oepi-loepi » Fri Aug 14, 2020 6:08 pm
Could you please activate the qt log and check the logs if any errors occur on the doorcam application when a fault occurs?
sed -i 's#startqt >/dev/null#startqt >/var/log/qt#' /etc/inittab ; init q ; killall -9 qt-gui
(the Toon will be retarted after this command), log will be in /var/log/qt
After all fault checking has been done you can disable the logging to free resources.
sed -i 's#startqt >/var/log/qt#startqt >/dev/null#' /etc/inittab ; init q ; rm /var/log/qt ; killall -9 qt-gui
(the Toon will be restarted after this command)
oepi-loepi
Postby stack » Sat Aug 15, 2020 10:40 am
what's the difference between these versions version 1.0.0 works well for me
stack
Postby oepi-loepi » Sat Aug 15, 2020 12:43 pm
the settings are saved to a different folder and are done in a different manner also resoures like icons and pictures are saved in the resource file instead of the folder itself.
oepi-loepi
Postby Micha_123 » Thu Aug 20, 2020 7:54 pm
i have the problem then i get a actual picture only after toon reboot.
the second time it shows only a frozen picture maked at the first time after rebooot.
i have deleted the doorcam app map, then i have it installed again from the toonstore but the same problem.
the old (manual version was working fine no problems but for now it's unusuable :(
anyone ideas about it ?
if not i do a revert to the first version
Micha_123
Postby michel30 » Thu Aug 20, 2020 9:54 pm
The screen picture is high ... could you also choose lower stream?
The problem is that the memory gets full of the Toon, it can not handle it high streams.
michel30
Postby oepi-loepi » Fri Aug 21, 2020 12:33 am
I have tested the toonstore app several times and i cannot find any problems. So the problems are a kind of instable and had to find. After i return from my holiday i will find some time to completely rebuild the app. For now: if you have problems, revert to the old manual app. Sorry but for now it seems the best solution in case of problems.
oepi-loepi
Postby Micha_123 » Sat Aug 22, 2020 1:45 pm
i have fixed it :D
in DoorcamFullScreen.qml file i added that line
app.doorcamImage1Source = "drawables/connect.jpg";
app.doorcamImage2Source = "drawables/connect.jpg";
this.close();
it was
this.close();
also added a map drawables in doorcam-1.1.1 and put connect.jpg into it.
now my camera is an 16:9 camera, but makes screenshots in an 4:3 resolution. so the toon shows an 4:3 picture and every one was verry long :D
i have fixed it making some changes in the DoorcamFullScreen.qml
Image {
width: parent.width - 110
height: parent.height - 30
fillMode: Image.Image.Stretch
source: app.doorcamImage1Source
anchors {
horizontalCenter: parent.horizontalCenter
top: parent.top
cache: false
z: app.doorcamImage1Z
onStatusChanged: {
app.doorcamImage1Ready = (doorcamImage1.status == Image.Ready)
MouseArea {
anchors.fill: parent
onClicked: {
app.pictureCountdownCounter = app.pictureCountdownCounterStart
Image {
source: app.doorcamImage2Source
anchors {
top: parent.top
cache: false
z: app.doorcamImage2Z
onStatusChanged: {
app.doorcamImage2Ready = (doorcamImage2.status == Image.Ready)
Rectangle {
width: parent.width
height: 20
color: "white"
anchors {
left: parent.left
bottom: parent.bottom
z: 10
maybe an idea, for the next release, in the config menu an "force 16:9" option and then there above config wil be used :D
Micha_123
Postby oepi-loepi » Sun Aug 23, 2020 12:05 pm
Thank you for fixing the problem. In the newest release i will apply some changes.
The actual connect.jpg location should be in the tsc folder ( app.doorcamImage2Source = "qrc:/tsc/connect.jpg"; ) instead of the drawables folder. I think i made the error there somehow...
Thanks again!
oepi-loepi
Postby Arcidodo » Fri Aug 28, 2020 7:05 pm
Is it possible to make this app to use with Home Assistant instead of Domoticz?
Arcidodo
Postby oepi-loepi » Fri Aug 28, 2020 8:37 pm
I think i should be possible since ha also has a rest api. However, i do not know enough of ha to make this work. If anybody knows how to do this, please feel free to adpat the code for ha.
oepi-loepi
PreviousNext
Return to Toon Apps
cron
