Toon app: Buienradar
Re: Toon app: Buienradar
hi all, version 8.5.7 is available in the ToonStore with a fix for the weather icon.
Unfortunatly it doesn.t solve the freezing problem
1 hour, 3 hour and 24 hour still freezes ;-(
you are referring to the moving radar maps, will have a look into that as well, 3hr view was broken but the others should work....
- Member
I checked but the one and three hours are not working.
Verstuurd vanaf mijn SM-G950F met Tapatalk
Here the same
referring to the moving radar maps, non of it works, nothing is moving I only see the time 16:30 with the screen.. If I press one of the times nothing is moving.. when I press 24 Hour.. it shows me only a screen 17:00 hour.
I had a quick look today but Buienradar has changed their image engine completely.
So far I couldn't get the animated gifs working again on Toon very quickly.
I will dive into this further after my holidays.
Ik zie geen Amsterdam en Almere om als Weer te instellen.
Kunnen jullie Amsterdam en Almere toevoegen?
The app will give you the option to choose one of the available weather stations provided by Buienradar. If your city isn't listed then there is no official weather station in your citymemo1996 wrote:Ik zie geen Amsterdam en Almere om als Weer te instellen.
After an reboot it works again
Today I upgraded the Toon to the latest firmware and I also see that Buienradar is working again
Currently the rain prediction tile can give rubbish data. This is caused by an issue with the data source file.
If buienradar.nl is not fixing it I could change our app to cope with it but I will first first report it and wait if they fix it.
i see this rubbish data to.Toonz wrote:Currently the rain prediction tile can give rubbish data. This is caused by an issue with the data source file.
Rooted Toon 1, Domoticz running on a RPI3b+, RFXCOM XL, RFLINK.
Hello All,
I updated my toon 1 to 5.33.9 yesterday (what a performance diffrence!)
I noticed that the widgets for buienradar are swapped in the gui.
If I add the rain prediction it will give me the weather info and vice versa.
Also clicking the icon in the top right from the home screen give me the rain radar instead of the weather info.
Is it me making some mistake or ..... ?
Thanks in advance,
Edwin
Thanks in advance,
Edwin
weird, never seen it. Probably best to uninstall buienradar, restart the gui and install it again.
(your settings will be saved)
