Don't reboot/hit reset because that will put your toon back into normal mode again
![Smile :)](./images/smilies/icon_smile.gif)
As the ToonRecovery also connects using serial (on the jtag wires) you can just open a serial interface on the Pi on serial port /dev/serial0
Didn't you use the backup and recover VPN config option of the recovery tool?PeJeWe wrote:i got the menu working and recovered it partially.
it can boot.
i have a backup of my VPN config but it is no longer in my toon.
were can i put the files
I accidentally deleted some files.TheHogNL wrote:Didn't you use the backup and recover VPN config option of the recovery tool?PeJeWe wrote:i got the menu working and recovered it partially.
it can boot.
You just need to place the backup back to the /etc/openvpn directory
That is the name it gets from the recovery. And when you restore the vpn config it will restore the hostname also.PeJeWe wrote:I accidentally deleted some files.TheHogNL wrote:Didn't you use the backup and recover VPN config option of the recovery tool?PeJeWe wrote:i got the menu working and recovered it partially.
it can boot.
i have now not my original eneco toon name it is now: eneco-001-000000
Thanks to you're guysTerrorSource wrote:You can change the name in /etc/hosts* files.
You where smart to backup your openvpn config during rootingPeJeWe wrote:The recovery program didn't found the VPN data because the files were not there anymore.
Because I had accidentally removed some files. (stupid me)
I had the VPN config files earlier backed up when I bought the the toon and rooted it.
Therefore the recovery program could not fix the VPN config problem.
The toon is now working fine because of the recovery program.![]()
Only the name of my Toon is wrong.
Can I change the name afterwards?
Euh,.. de toonrecovery maakt een backup van je VPN key voordat hij gaat formatteren .. heb je die optie misschien overgeslagen?toontoon2 wrote:nevermind heb het gefixed.
Wellicht ter referentie voor anderen met zelfde probleem:
1) Root je oude toon en gebruik WinSCP om de hele etc/OPENVPN map te kopieren naar je harde schijf. Kopieer ook het bestand etc/hosts
2) Root je nieuwe toon (gebruik optie -f, want je gaat niet kunnen updaten omdat VPN niet werkt) en gebruik daarna WinSCP om de contents van de gekopieerde OPENVPN map te kopieren naar je nieuwe toon.
3) Kijk in het bestand etc/hosts die je hebt gekopieerd naar je harde schijf om te zien wat de naam is van je oude toon (eneco-001-xxxxx). Open vervolgens het bestand etc/hosts op je nieuwe toon en zoek naar eneco-001-0000 of iets vergelijkbaars. Vervang deze naam met de naam van je oude toon.
Reboot je toon, en probeer nu te updaten met het scriptje, Als het goed is nu je VPN wel online en kan je updaten.
Success!
En maak niet mijn fout door te snel alles te willen doen en maak altijd een backup indien er de optie voor is
Ik had gelukkig nog een dode toon liggen in een doos, anders was het weer een tripje naar marktplaats....
Ja... ongeduldigheid...TheHogNL wrote:Euh,.. de toonrecovery maakt een backup van je VPN key voordat hij gaat formatteren .. heb je die optie misschien overgeslagen?toontoon2 wrote:nevermind heb het gefixed.
Success!
Ook in /etc/hostname en /etc/network/interfaces moet je de hostname aanpassen overigens.toontoon2 wrote:nevermind heb het gefixed.
