I disabled all the standard Toon apps in the TSC menu. But after a FW update the Smokedetector app is visible but still disabled in the TSC menu.
A quick fix is to enable and then immediately disable the Smokedetector app and then reboot the GUI. I needed to do this after several updates.
Smokedetector app not disabled after FW update
Re: Smokedetector app not disabled after FW update
Ok i'll check that when I have some spare time. No priorities.
I don't have that issue anymore with the Smokedetector app. But the Status Usage app has the same problem.
And could the Slim Verwarmen app also added to the list?
You can also turn it off yourself. Change in /qmf/qml/config/TenantSettings.json "appHeatingOverviewEnabled" to 'false'. (Thanks to thehognl)
Yes, that got rid of the "Slim verwarmen" app. Thanks! The "Status verbruik" app is still loaded though.. Can anybody tell me which app to disable?Daniel wrote:You can also turn it off yourself. Change in /qmf/qml/config/TenantSettings.json "appHeatingOverviewEnabled" to 'false'. (Thanks to thehognl)
TenantSettings.json
"appWeather": "",
"appGraphTileLowestUsage": true,
"i18nLocales": [
"nl_NL",
"en_GB"
"appWhatIsNewAutostart": false,
"enabledHeatingSourceConfiguration": false,
"enabledGasMeterConfiguration": false,
"appEMetersSettingsAdvancedDisabled": false,
"appSystemSettingsFactoryResetDisabled": false,
"appControlPanelSmartplugHardRemoveDisabled": false,
"appControlPanelPinProtectRemoveBridge": false,
"appControlPanelLampRenameDisabled": false,
"appControlPanelPlugRenameDisabled": false,
"appControlPanelHueSceneSaveDisabled": false,
"featSMEEnabled": true,
"featShowEnergyMeterImages": true,
"featHolidayOffPeakEnabled": true,
"featSmokeDetectorSensitivityEnabled": true,
"featAlarmControlEnabled": true,
"featHumidityEnabled": true,
"featContactSettingsTabEnabled": true,
"appSolarEnabled": true,
"appBenchmarkEnabled": false,
"appWhatIsNewEnabled": false,
"appWhatIsToonEnabled": false,
"appSmokeDetectorEnabled": false,
"appHeatRecoveryEnabled": false,
"appCustomerServiceEnabled": false,
"appInboxEnabled": true,
"appUpsellEnabled": false,
"appHeatingOverviewEnabled": false,
"installationWizardApps": [
"internet|true",
"activation|true",
"update|false",
"emeters|false",
"boiler|false"
"appBoilerMonitorEnabled": false,
"appStatusUsageEnabled": false
Did you eventually manage to turn off the usage status, I can't get him out of here either, i've got appStatusUsageEnabled": false TenantSettings.json
In TSC menu / subscription "Status usage app"is off, but still "Status verbruik"is loaded and the icon shows in the systray.
Any solutions how to get rid of it?
Templar wrote:Yes, that got rid of the "Slim verwarmen" app. Thanks! The "Status verbruik" app is still loaded though.. Can anybody tell me which app to disable?Daniel wrote:You can also turn it off yourself. Change in /qmf/qml/config/TenantSettings.json "appHeatingOverviewEnabled" to 'false'. (Thanks to thehognl)
TenantSettings.jsonCode: Select all
{ "appWeather": "", "appGraphTileLowestUsage": true, "i18nLocales": [ "nl_NL", "en_GB" ], "appWhatIsNewAutostart": false, "enabledHeatingSourceConfiguration": false, "enabledGasMeterConfiguration": false, "appEMetersSettingsAdvancedDisabled": false, "appSystemSettingsFactoryResetDisabled": false, "appControlPanelSmartplugHardRemoveDisabled": false, "appControlPanelPinProtectRemoveBridge": false, "appControlPanelLampRenameDisabled": false, "appControlPanelPlugRenameDisabled": false, "appControlPanelHueSceneSaveDisabled": false, "featSMEEnabled": true, "featShowEnergyMeterImages": true, "featHolidayOffPeakEnabled": true, "featSmokeDetectorSensitivityEnabled": true, "featAlarmControlEnabled": true, "featHumidityEnabled": true, "featContactSettingsTabEnabled": true, "appSolarEnabled": true, "appBenchmarkEnabled": false, "appWhatIsNewEnabled": false, "appWhatIsToonEnabled": false, "appSmokeDetectorEnabled": false, "appHeatRecoveryEnabled": false, "appCustomerServiceEnabled": false, "appInboxEnabled": true, "appUpsellEnabled": false, "appHeatingOverviewEnabled": false, "installationWizardApps": [ "internet|true", "activation|true", "update|false", "emeters|false", "boiler|false" ], "appBoilerMonitorEnabled": false, "appStatusUsageEnabled": false }
No, I didn't. Haven't got any solutions either.rleunk wrote:Did you eventually manage to turn off the usage status, I can't get him out of here either, i've got appStatusUsageEnabled": false TenantSettings.json
Oke, too bad, maybe in time there will be a solution. I will have to deal with it for now sounds worse than it is.
