you can start here domoticaforum.eu/viewtopic.php?f=66& ... mp;start=0Error323 wrote: For my attempt in home automation I want to bypass the cube completely and control the valves directly via a 868 MHz transceiver. Does anybody here know the internal protocol between cube and valve components? I can't seem to find it anywhere, is it FHT based or completely different?
ELV MAX! protocol description
Moderator: jrkalf
Re: ELV MAX! protocol description
Excellent! Thank you!
i really can't see the advantage of bypassing the cube (except the €30 not spent, obviously
).. could you please explain me?
this is my first post and came across this very interesting topic.
Has anyone tried the protocol on Ethernet socket base with a wago controller 750-880 implemented.
MacToolz
MacToolz
- Starting Member
Regarding wall thermostat (device type = 3), the L message contains 12 bytes. Length is 12 (of course
) and last byte represents the real temperature x 10.
0xaf => 175 => 17,5 degrees
Philippe
Philippe
Don't know if you have a new type wall thermostat Philippe, but my wall thermostat L message is 7 bytes long whereas the actual temperature is represented by the MSB bit of the third byte together with the seventh byte ( x 10).philjung77 wrote:Hello,
Regarding wall thermostat (device type = 3), the L message contains 12 bytes. Length is 12 (of course) and last byte represents the real temperature x 10.
Philippe
Peter
Peter.
http://www.adreamerslair.nl
12th byte is actual temp*10, so theres a limit: 25,5 degrees. if it's higher, the count starts from 0 again and the first bit of byte 8 (set temp) is set to onepbrand wrote:Don't know if you have a new type wall thermostat Philippe, but my wall thermostat L message is 7 bytes long whereas the actual temperature is represented by the MSB bit of the third byte together with the seventh byte ( x 10).philjung77 wrote:Hello,
Philippe
Peter
This is the standard wall thermostat.
I don't believe your response can be simply 7 bytes, as always it will be 6 bytes for ecoswitch, 11 for radiator thermostat and 12 for wall thermostat.
Maybe you are not counting starting bytes
1) data lenght
2,3,4) rf address
5) unknown
So then there are 7 bytes
Oh silly me. You are quite right, Massi. I only looked at the specific device bytes and forgot about the generic part
Peter.
No, you'll not get excused.pbrand wrote:Oh silly me. You are quite right, Massi. I only looked at the specific device bytes and forgot about the generic part
For that, you need to add to you blog the protocol description of the s: command
it may be that in the new firmware 1.4.1, the commands have changed in their byte protocol?
Thanks
MacToolz
Thanks
MacToolz
my "simple" commands (manual temp set) still work. What commands are you referring to?mactoolz wrote:Hi,
Thanks
MacToolz
i want to use all the commands. At least M / H / C / L and also the sending of data.
e.g. the byte arrangement of the M command I am missing some information. Rather, I do not know what type specific bytes of information again.
e.g. I have not in my receiving data, the RF address.
Look Please purely in the excel. Since I have the Empfangsdasten divided times.
You may find, for example, the RF address.
Thanks
MacToolz
Thanks
MacToolz
- M-Command XLS.xlsx
- M-Command list recorded from wireshark
- (18.77 KiB) Downloaded 1249 times
I am running 1.4.1 firmware here and have seen no changes in the M / H / C / L messages.
Peter.
Full quote.pbrand wrote:I am running 1.4.1 firmware here and have seen no changes in the M / H / C / L messages.
No changes in last firmware
have you looked at the excel. This is an excerpt from the M command. I see no RF address here. The first topic is described which can be seen in the M-command for a device address.
I do not see them unfortunately. Can you tell me the individual bytes?
Thanks
MacToolz
Result JEQ0416392 --> 21('21') 3('3') 1('1') 210('Ò') 240('ð') 74('J') 69('E') 81('Q') 48('0') 49('1') 54('6') 51('3') 57('9') 50('2')
Result AZ_WandThermo --> 48('0') 13('CR') 65('A') 90('Z') 95('_') 87('W') 97('a') 110('n') 100('d') 84('T') 104('h') 101('e') 114('r') 109('m') 111('o')
MacToolz
