Toon app: Buienradar
Re: Toon app: Buienradar
having a productive evening I guess.
The new buienradar app (version 8.3.3) is available on the ToonStore.
Changelog 8.3.3:
- permissions on root folder should not be touched anymore (was used in the past for the https workaround). Please test for those impacted and let me know whether it is ok now.
- clicking on the rain prediction tile now opens the big radarimage screen
- clicking on the small buienradar image in the weather details screen also brings you to the big radarscreen.
- your exact location can be set now by clicking on 'Locatie' on the big radarimage screen
This will exactly position the yellow markers and set the location for the rain tile.
- added the 'Motregenradar' option to the big radarscreen
- your config settings (weather station and exact location) are now properly moved to the new version's folder
and the old buienradar version's folder is properly deleted
Kind regardz,
Toonz wrote:permissions on root folder should not be touched anymore (was used in the past for the https workaround). Please test for those impacted and let me know whether it is ok now.
Works. Thanks!
Hypermobile
Post by Hypermobile »
Minor issue:
when changing from Regenradar to Motregenradar
Aspect ratio of the map changes.
Motregenradar is a little less high.
glsf91
Post by glsf91 »
Thanks. Looking great!
ronalddehaan
Post by ronalddehaan »
Hi Toonz,
Just a quick question, I don't know if it's been asked before or not, but is it normal that the Buienradar app is 'updated' every day?
I am getting 'update' messages in my inbox on a daily bases (at 01.00) that the app has been updated. The version, however, only changes ever so often.
Please let me know :)
ronalddehaan wrote:Hi Toonz,
No it's not. Probably a bug in the ToonStore. I recommend disabling the auto-update function for now in the ToonStore settings.
Will have a look at it.
ronalddehaan
Will do, thanks!
hayman
Post by hayman »
hello,
im on ver 3.2.18 and can't update to the new one,
is there any way to get buienradar_8.3.3 working,,?
thanks
hayman wrote:hello,
thanks
I can't test on a firmware that old :-( (My 'oldest' Toon is at 3.7.9).
Does the app install correctly?
If yes, is it working but just doesn't show data?
In that case it could be that https is not supported on that firmware.
Your only option then is to use 8.2.1 with the cron/curl jobs to retrieve the data outside the Toon gui.
In case the app is not running properly (no tile on Toon), can you share the part of the console output where the buienradar app is starting....It most likely gives you an error there.
Those can be fixed most likely.
Kind regards,
Will give it a try. My production toon is still 3.2.18 :-) (If it ain't broke, don't fix it).
Post by TheHogNL »
marcelr wrote:Will give it a try. My production toon is still 3.2.18 :-) (If it ain't broke, don't fix it).
So it's time to update now. It is broken :lol:
hayman
Post by hayman »
Toonz wrote:
hayman wrote:hello,
thanks
Kind regards,
the new app doesn't install ,but the old one it install will,and work ...
so there is no way to update the toon .?
Post by TheHogNL »
I just sent you in a privmsg the normal method.
In short, you first need to enable openvpn again and most of the time the 'update' button will apear right after you check the 'software' screen in Toon.
And remember that enabling openvpn and updating a Toon will overwrite a few files which will probably unroot your Toon a bit (which is easily fixed afterwards, but better to prevent it)
globegrabber
Post by globegrabber »
Hello Toonists,
Like to throw the next two questions in the group, is there a possibility to expand the Buienradar app, with the realtime map of the EU, This will give a better use of Toon in combination of the language, I like the use of the EU map for a longer term. and for the second question, of it is possible to edit the time of playback of the pictures, i myself find this rate at this a little to fast, so if there is a way to slow it down, maybee by implementing a setting in the app to give a time preset. i think there will be interest for these.
Maybee a few ideas for a later upgrade!
With kind regards,
Globegrabber
Probably both are possible. Will have a look....
EDIT: will add the EU map to next version. Have not yet found the parameters to controls the image cycle speed.
