Toon firmware - update script
Post by TheHogNL »
ArieKanarie wrote:
TheHogNL wrote:What is the output of the script?
You mean the output during the process, or can I find a logfile somewhere?
During the process.
ArieKanarie
Post by ArieKanarie »
See https://pastebin.com/raw/hVG6kK03
Could it be that the problem is in here...?
Warning: upgrade script from source server is changed. Do you want to continue downloading the files (if not sure, type no and report in the forums)?
Because the preparation and upgrade both are ready in 1 second (and stuck at 0%)
Progress: 0% .
Done preparing.
Are your sure you want to upgrade to 4.10.6 (yes)? This is the last moment you can stop the upgrade. Answer with 'yes' will start the upgrade.
yes
Starting the upgrade now! Just wait a while... It can take a few minutes.
Progress: 0%
Upgrade done!
Post by TheHogNL »
No I don't think that the changed script is causing this.
Could you check/show me the /mnt/data/update/upgrade-qb2.sh.log file?
ArieKanarie
I Could, but I don't have a directory "data" in /mnt
To be precise, the dir /mnt is completely empty.
Post by TheHogNL »
ArieKanarie wrote:I Could, but I don't have a directory "data" in /mnt
Owh then it is located in the old /HCBv2/tmp/opkg-cache location
ArieKanarie
>> deleting all in /HCBv2/tmp/opkg-cache
>> (this may give some errors, no problem here ...)
rm: can't remove '/HCBv2/tmp/opkg-cache/*.ipk': No such file or directory
rm: can't remove '/HCBv2/tmp/opkg-cache/*.sh.sig': No such file or directory
>> 2018-05-15 06:33:19 +0000 (pid 25506), status = executed
>> Restarting qt-gui and hcb_config ...
>> 2018-05-15 06:40:25 +0000 (pid 901), status = prepare
>> Welcome to the ToonStore updater,
>> brought to you by the Toonroot Software Collective (TSC)
>> 2018-05-15 06:40:25 +0000 (pid 901) upgrade-qb2.sh qb2 ene 4.10.6 prepare
>> 2018-05-15 06:40:25 +0000 (pid 901), status = preparing
>> Firmware version: 3.2.18, build 962, rev 0.
>> System load     : 0.51
>> Free RAM        : 2148K
>> Flushing file system buffers and cache ...
>> Free RAM now    : 8180K
>> Hotfix for writing System Time to RTC
Hardware Clock before: Tue May 15 06:40:26 2018  0.000000 seconds
Hardware Clock after : Tue May 15 06:40:26 2018  0.000000 seconds
rm: can't remove '/var/lib/opkg/tsc*': No such file or directory
>> no packages to process, exiting ..
>> 2018-05-15 06:41:02 +0000 (pid 1063), status = execute
>> 2018-05-15 06:41:02 +0000 (pid 1063), status = executing
>> reinstating cache handling (default 0)
>> deleting /tmp/install_status
>> 2018-05-15 06:41:02 +0000 (pid 1063), status = executed
>> 2018-05-15 07:00:25 +0000 (pid 2136), status = prepare
>> 2018-05-15 07:00:25 +0000 (pid 2136) upgrade-qb2.sh qb2 ene 4.10.6 prepare
>> 2018-05-15 07:00:25 +0000 (pid 2136), status = preparing
>> System load     :
>> Free RAM        : 1988K
>> Free RAM now    : 9736K
Hardware Clock before: Tue May 15 07:00:27 2018  0.000000 seconds
Hardware Clock after : Tue May 15 07:00:27 2018  0.000000 seconds
>> 2018-05-15 07:00:31 +0000 (pid 2242), status = execute
>> 2018-05-15 07:00:31 +0000 (pid 2242), status = executing
>> 2018-05-15 07:00:31 +0000 (pid 2242), status = executed
- upgrade-qb2.sh.log 482/482 100%
could be that ToonStore is already installed earlier, in that case opkg skips installation.
Can you try 'opkg remove toonstore' first and then run the updater again?
ArieKanarie
Removed as you said.
Now I get:
Which version do you want to upgrade to?
4.10.6
Alright, I will try to upgrade to 4.10.6
Could not download the upgrade script from the source.
Damn post moderation! :D
Post by TheHogNL »
I think your /etc/hosts file is broken.
Normally, if the VPN is started, the host entry for 'feed.hae.int' will be added in there but it is not working for you.
Please post the contents of the /etc/hosts file
Ierlandfan
Post by Ierlandfan »
Just reboot to make sure.
Then do a "ps -w |grep openvpn" to see if openvpn is started. If yes..
Then try "opkg update" It should give you a lot of output.
Don't worry. That command doesn't do anything. It's just checking if the list of new packages can be downloaded.
If it stalls or says something in the line that says "failed", then post back.
If above fails you can try to manually enable openvpn by issuing
"/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0"
Then try "opkg update". If it stalls or says something in the line that says "failed", then post back.
Post by TheHogNL »
Ierlandfan wrote: If above fails you can try to manually enable openvpn by issuing
I would not start the openvpn manually (without the upgrade script). This will allow your Toon to connect to the servicecenter and therefore overwrite the scsync.xml file which contains your subscription etc. You need to restore those settings afterwards again then.
I'm pretty sure his /etc/hosts file is wrong. I have seen multiple old versions of toon not updating the /etc/hosts file correctly.
ArieKanarie
TheHogNL wrote:I think your /etc/hosts file is broken.
I have had troubles with the hosts file, I was sure I've already posted it somewhere (here or domoticz forum) but can't find it back.
The problem was that the hosts file was changed everytime with the known entries, but then all on one line, like:
# <persistent /etc/hosts content from /etc/hosts.template file>127.0.0.1 ping.quby.nl127.0.0.1             feed.hae.int            feed
One of the reasons I wanted to do a upgrade.
My current hosts file is:
# </persistent /etc/hosts content from /etc/hosts.template file>
127.0.0.1               localhost.localdomain           localhost
172.19.96.1             feed.hae.int            feed
So, with double entries, and the quby entry here? (If I am not mistaken that one should be in hosts.template?)
Just removed the upper part, try the upgrade again, but the hosts file is now again the same with double entries.
Post by TheHogNL »
I'll contact you in a PM
Post by TheHogNL »
His old version had a problem with the hosts.template file. Once corrected the updates went fine.
ArieKanarie
Thanks for the help.
Now going to dive into the vnc adventure. 8)
Return to “Toon Firmware”
