Toon app: Kalender
Xavier
Re: Toon app: Kalender
Post by Xavier »
how can I check the size of the calender?
What is too big?
you can download the calendar in your browser and check the size.
What is 'too big' is dependent on the other installed apps and available memory.
Typically old entries of (specifically google calendars) are not purged regularly.
That would be my first tip: check your calendar and remove expired entries.
The app needs to read all entries to be able to check if there are recurring items which have valid entries in the future to be displayed
Xavier
Post by Xavier »
I just found something in relations to an API for the Google calender. In the API based on Python I found some code which seems to make it possible to download/view calender events on a specific moment, for example "today".
This is the link where I found this information:
https://developers.google.com/calendar/ ... art/python
Can something be done with this information?
Xavier wrote:...Can something be done with this information?
The Kalender app is designed to read generic ICS files from any provider.
In principle this google api can be implemented but that would be usefull only for google calendars.
I don't think I will implement it unless someone has compelling reasons why it should be done.
Another disadvantage is that you will need to store your google logon credentials on Toon.
Kind regardz,
Xavier
Post by Xavier »
Ok, I understand, thought it would helpfull so that not the entire ICS file has to be downloaded first, since it gives me a lot of performance issues.
But point taken about the credentials on Toon
Performance is probably a valid point.
On the other hand, Google is lacking any archiving functionality for old items, that's the real issue in my view.
Maybe, when I have time, I will see if I can implement this.
First need to do some waste calendar maintenance
Xavier
Post by Xavier »
Would really appriciate it, no pressure ;)
estate
Post by estate »
Hi :)
I have a few questions about how to get the calendar working and for what I have found I need a Google URL to my private cal. (which I have found and copied to my pc)
Then I need to copy this link in the userSettings,json file but where can I find that file on the Toon ?
I have searched and can not find it ? should i copy that file ? I have downloaded the json zipped file in post 3 or 4 ? from this topic .
you can find the userSettings.json file in /qmf/qmf/apps/calendar after installation of the calendar app
N.B. there will be a next release soonish where this json file will be moved to /mnt/data/tsc
estate
Post by estate »
Hi again Toonz :)
Found the map and the json file, there is already an entry in it with the Dutch holidays, which I like to keep :) is it possible to add my private agenda to it ?
I guess its just copy paste and replace the http.... with my own or am I wrong ?
Can you give me an example ?
estate
Post by estate »
@Toonz,
Hi mate :0 I found and setup the calendar(s) but as far as i can see only my Google calendar is hown after changing the json file and I do see both my private and the "feestdagen" calendar.
Thanks for helping me out again :) (jeah I know I'm a real PITA :) thanks :)
ArieKanarie
Post by ArieKanarie »
For the people who are facing the issue of a large calendar due to history (my calander went back to 2012, which caused the toon to continious reboot when downloading the calendar), this app is a great help; you can clean your calendar from a specifick date.
If you would like to keep the history you could make an export & import before deleting.
https://play.google.com/store/apps/deta ... l&hl=en_US
When started the app it said it was an older app not optimized for my device (s8) but it worked perfectly.
ArieKanarie
I reinstalled the app on toon (in the search of troubleshooting), and now everytime i change the usersetting file, my changes are undone when the toon is rebooted?
Just the public holidays calender is in the file after that?
can you pm me your userSettings file?
ArieKanarie
The current one, or the one I am trying to make?
