Can you tell us what is being downloaded?
Dunno, something like this?
(from happ_weather.html, v 2.9.15):
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<title>Null Devices</title>
<style type="text/css">
	@import "/style/config.css";
	@import "/inc/dojo-new/dijit/themes/dijit.css";
</style>
<script type="text/javascript" src="/inc/dojo-new/dojo/dojo.js" djConfig="parseOnLoad: true, usePlainJson: true"></script>
<script type="text/javascript" src="/inc/dojo-new/dojo/dojo-hcb.js"></script>
<script type="text/javascript">
dojo.require("hcb.utils");
dojo.require("hcb.translate");
dojo.require("dijit.form.Button");
</script>
dojo stuff and a bit of css? Both not to be found locally on toon.
grtz,
al_n
Post by al_n »
toon has a communication hub running locally on port 1337, you can also telnet into it.
I believe this is the heart of everything which is happening on toon.
here is a tcpdump example.
al_n
Post by al_n »
a fast look in the dump thought me that I can do:
http://10.10.10.7:7080/happ_thermstat?action=changeSchemeState&state=0&temperatureState=0
or
http://10.10.10.7:7080/happ_thermstat?action=changeSchemeState&state=0&temperatureState=1
to change program :lol:
I believe that now we can identify all the needed parameters.
Yes.
And Eneco can identify you. You just dumped your toon's serial number onto the internet ...
grtz,
al_n
Post by al_n »
I'll be careful for the eneco gestapo come knocking on my door :)
al_n
Post by al_n »
Is there any way to manually upgrade to QT version?
If you have all the update files, it's a piece of cake. Just install, using opkg. Probably you have to go through all update steps from 2.9.6 to 3.x.xx, one by one.
Otherwise, you should find someone who is ready to send you all the images (/dev/mtd0 - /dev/mtd4, IIRC) to be able to reflash the machine (wouldn't do that without working JTAG access, if I were you).
Third option: buy another one from MP, with newer software. The bad News is that prices haven gone up steeply since the summer holidays. Bought a toon for 25,-- with delivery included, last august. That's not very likely to happen again today (why is News printed with a capital n, that's the second (and third) time already, this week. I _am_ typing an n, not an N).
Final option: sign an Eneco contract, and get the updates as part of the deal 8). Would be a sign of weakness, though :lol: :lol: :lol: .
I'm not sure if you need a full update. Probably, updating the contents of /HCBv2 and some stuff in /etc should do the trick. The linux kernel and the rootfs haven't changed that much from version to version.
grtz,
al_n
Post by al_n »
I think that an HCBv2 is not enough. probably need /lib as well.
I'll be happy if you could make a copy.
al_n
Post by al_n »
My whole interest in rooting the toon is because I've got one second hand and I'm not an Eneco client (and not intend to become one anytime soon) but I do like to be able to control it remotely.
Basically I figured out that I can do most of the stuff with the following handlers (use your own ip address):
http://10.10.10.7:7080/happ_thermstat?action=changeSchemeState&state=0	program off
http://10.10.10.7:7080/happ_thermstat?action=changeSchemeState&state=1	program on
http://10.10.10.7:7080/happ_thermstat?action=changeSchemeState&state=0&temperatureState=0	comfort
http://10.10.10.7:7080/happ_thermstat?action=changeSchemeState&state=0&temperatureState=1	home
http://10.10.10.7:7080/happ_thermstat?action=changeSchemeState&state=0&temperatureState=2	sleep
http://10.10.10.7:7080/happ_thermstat?action=changeSchemeState&state=0&temperatureState=3	away
http://10.10.10.7:7080/happ_thermstat?action=setSetpoint&Setpoint=2350	set to 23.50 deg
together with
http://10.10.10.7:7080/happ_thermstat?action=getThermostatInfo
for feedback
now just to put it all in a little app, secure toon's web server with mod_auth and open it to the internet.
Just to follow up on the previous post, attached to this one is the list of installed packages on my toon (/usr/lib/opkg/status, SW 3.0.32), so you can check against yours what has been renewed.
As you can tell from the UNIX timestamps, many packages have never been updated since they were first installed.
grtz,
status.zip
package list SW 3.0.32
(4.4 KiB) Downloaded 627 times
al_n
Post by al_n »
I think it's too much to do it manually and be safe about it.
status.diff.zip
(1.04 KiB) Downloaded 530 times
Don't know, it's just /HCBv2, the kernel and a few libs. No big deal if you ask me. I don't think you have to replace the kernel.
grtz,
al_n
Post by al_n »
in my inittab I have the flash gui fired up. what is it replaced with?
al_n
Post by al_n »
there is another http server running on port 5555 which is open and is started by the "hcb_upnp" process. I wonder what can be done there?
EDIT: I believe it has to do with smart power outlets and the philips hue lamps.
The QT gui ...
grtz,
Return to “Toon Rooting”
