Sadly i don't agree with this statement.raymonvdm wrote:Is there anyone using amplifiers for output 1 - 8 which are actually line-out terminals so the should need an additional amplifier.
I depend on your needs. None of the 9 locations here have amplification. Yes you need an amplifier if you want to sound at disco levels however in my opinion for normal daily use the output is loud enough. Actually if i raise the volume on the PC and in the unit to a level that it won't distort then the volume is to annoying to have a normal conversation in the livingroom. On the other side, the music that plays under my bed in the morning at 06:00 is very soft. Just to get me slowly awake and not with a bang like those buzzer clocks
However if you need some extra amplification then this is a cheap solution. One board can amplify 2 channels.
miniinthebox.com/nl/mini-digital-3w-3-w ... 73310.html
