What motion sensors?
DMB
Post by DMB »
Snelvuur, Chak (We were typing at the same time)
That's the same old trick for me now also. (See example in this topic. When I've 2 motionsensors for the same light I use the &hs.removedelayedevent to delete the event when motion is detected.
I will make a test with the doomotion again.
DMB
Noel
Post by Noel »
best place for buying Kaku devices is at the moment Karwei.
@Wifi,
I have all my Kaku devices from Karwei in Nieuwegein.
Did they sell any other Kaku devices?
Formida also have them...price is only a bit higher
I think also Gamma is selling Kaku devices
check kaku website for the dealers
http://www.klikaanklikuit.nl/dealers.asp
there also some online shops
http://www.mypowershop.eu
DMB
Post by DMB »
Wifi,
I bought them at the Gamma in Deventer.
DMB
Noel
Post by Noel »
Thank you both for the reply.
I have some Gamma's close to where I live.
Tomorrow I'll give it another go.
<h6>Anyone interested in time travel meet me here last Thursday!!</h6>
Noel
Post by Noel »
Okay.
Got a Kaku AWST-6000 today from the Gamma.
I've put two AAA's in it, moved the Learn switch from the AWST-6000 to "SET", and (in HomeSeer) opened RFXCOM > Input dev. > "ADD", but for some reason it's not seeing the AWST-6000. (message No devices found to add!"
Am I doing something wrong here, or is it just not my day, and did I get a dead AWST-6000?
Wifi
You have to check the AC input.
After that make motion via AWST-6000
see the screenshot..
[img]uploaded/Chak/2008524213549_rfxcom-ac.gif[/img]
Noel
Post by Noel »
Chak,
I've set all the inputs already some time ago.
X10, ARC, OS, AC and ATI are all set.
I'm Still getting a "No devices found to add!".
I'm about ready to give a new set of battery's a go.
uncheck the rfxcom input save and then recheck.
what you also can do is close HS en test it with rfxcom receiver application.
Noel
Post by Noel »
<br />uncheck the rfxcom input save and then recheck.
DMB
Post by DMB »
Wifi,
Did you put the LEARN switch to SET. (OK, you did , I did not read well.)
The AWST will send the code in this mode.
The switch must be set retour on DEL.
Another possibility is the version of your RFXCOM receiver.
It must be the latest version otherwise the new KAKU modules are not recognized.
DMB
Noel
Post by Noel »
I guess the RFXCOM receiver I have could be old? (it's only about 2 months old!)
How do I get the version number (I think I needed to do this with the RFXcom receiver software?)
Varions that works fine with Kaku
Version request to receiver => F020
4D24538E Version Master=24 Slave=8E
Version request to transmitter => F030F030
RF Modes are reset to: X10 enabled and all other modes are disabled.
Transmitter Firmware Version: 10
Noel
Post by Noel »
This is what I get when using the RFXcom receiver software and using the button "Get receiver version"
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Version request to receiver => F020
4D23 Version Master=23<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">.
Is this an 'old' receiver? If so. Is it just an 'software' thing (like flashing), or a hardware update to get the 'KAKU' stuff to work?
NEW HomeEasy and KlikAan-KlikUit with automatic code system. (req. receiver V24)
