Page 2 of 4
Re: Toon app: Traffic information
Posted: Fri Oct 04, 2019 7:14 pm
by Xavier
Since my Toon2 the traffic info app doesn't work anymore.
I get the following error:
"Verkeersinformatie ophalen mislukt. Geen internet verbinding" while all other apps work just fine. So no issue with the internet connection.
Anyone else with this problem?
Already removed and reinstalled the app and reboot but without succes......
Posted: Fri Oct 04, 2019 7:23 pm
by Toonz
same here. Traffic data is retrieved from
http://xml.fileindex.nl/ but that site is not responding at the moment (also not with https).
Posted: Fri Oct 04, 2019 7:30 pm
by Xavier
DNS lookup doesn't resolve anymore....
Posted: Tue Oct 08, 2019 5:02 pm
by Xavier
Still no fix?
Posted: Tue Oct 08, 2019 5:38 pm
by Toonz
No, and not expecting it to be resolved. It seems the service has been discontinued.
I blocked the app for new installs via the ToonStore, you can only uninstall.
Posted: Fri Oct 11, 2019 9:22 pm
by Xavier
will a new app be released?
Posted: Fri Oct 11, 2019 9:55 pm
by Toonz
only if you can find a new free source of traffic info I can make a new app
Posted: Fri Oct 11, 2019 10:23 pm
by Xavier
Posted: Fri Oct 11, 2019 10:28 pm
by Toonz
none of these give a clean xml or json feed.
Will have to scrape the html source, is possible but quite some work. Which need to be redone each time they change their website
Posted: Fri Oct 11, 2019 10:35 pm
by Xavier
ahh get it, you're looking for XML or json format.
Posted: Sat Oct 12, 2019 3:36 am
by HansieNL
Posted: Sat Oct 12, 2019 1:49 pm
by Toonz
Great stuff
Thanks for the link, looks very usable.
I will change the app to use this source.
EDIT:app works again but I need to redesign the screen with traffic jam details because the info provided has a different structure. It also has a section for 'flitsers' but I need to check whether that will be populated during the day (is empty now)
Posted: Sun Oct 13, 2019 11:46 am
by Xavier
I get an error that it doesn't work on 5.13.12 firmware. Can 't reinstall the app.
Posted: Sun Oct 13, 2019 12:20 pm
by TerrorSource
Xavier wrote:I get an error that it doesn't work on 5.13.12 firmware. Can 't reinstall the app.
Can you try logging in via SSH and do a "opkg remove fileinfo" ? Reboot afterwards.
That should remove the Fileinfo app so you can re-install it after the reboot.
EDIT: Don't do this, see next post from Toonz
Posted: Sun Oct 13, 2019 1:55 pm
by Toonz
currently you can only uninstall the app via the ToonStore for the simply reason that the current app in the ToonStore doesn't work anymore due to the data source being unavailable. When the new app is completed it will be available through the ToonStore again.
Manual installation of the current version is unnecessary and completely useless
