QML Questions
robgeerts
Re: QML Questions
Post by robgeerts »
I load SwitchItem.qml in code below (in the Repeater).
Is it possible to load another qml-file in an if-statement?
(If type=a, load Switchitem, otherwise load Otheritem)
Grid {
		spacing:10
		columns: 4
		rows:5
		visible: app.devicesReceived
		anchors {
			top: btnRow.bottom
			topMargin: 10
			left: parent.left
			leftMargin: 32
		Repeater {
			model: app.devices
			SwitchItem {
				idx: model['idx']
				title: model['Name']
				status: model['Data']
				lastupdate: model['LastUpdate']
robgeerts
Re: QML Questions
Post by robgeerts »
With the function below (from boilerapp) I always get a timeout.
The url is working because when I open it in the browser it shows me the correct JSON-output.
function httpRequest(requestType, url, callback, data) {
		var http = HttpRequestFactory.create();
		http.finished.connect(function() {
			http.finished.disconnect(arguments.callee);
			console.log("Req: request done\n  code:", http.responseCode, "response:", http.responseText);
			if (callback !== undefined) {
				callback(http.responseCode, http.responseText);
		http.error.connect(function() {
			http.error.disconnect(arguments.callee);
			console.log("Req: request error\n  status:", http.status, http.responseCode, http.statusText);
		http.timeout.connect(function() {
			http.timeout.disconnect(arguments.callee);
			console.log("Req: request timeout");
		http.open(requestType, url);
		http.setRequestHeader("Accept", "application/json");
		http.send(data);
Re: QML Questions
Interesting, never used the function HttpRequestFactory. So far I did everything with XMLHttpRequest.
This function is introduced very recently (from 4.8/4.9 onwards), need to dive into it a bit.
Congratulations with your 10th post :D :D :D :D
robgeerts
Re: QML Questions
Post by robgeerts »
Thanks!
Well, I've tried getting the JSON with XMLHttpRequest, it worked, but using the data didnt...
var xmlhttp = new XMLHttpRequest();
xmlhttp.onreadystatechange=function() {
	if (xmlhttp.readyState == 4) {
		if (xmlhttp.status == 200) {
                        console.log("Result JSON: "+xmlhttp.responseText);
			var res = JSON.parse(xmlhttp.responseText);
			devices = res["result"];
			devicesReceived = true;
xmlhttp.open("GET", "http://192.168.1.3:8084/json.htm?username="+username+"&password="+password+"&type=devices&favorite=1&filter=all&used=true&order=Name", true);
xmlhttp.send();
In the console from the code above, I only get: {
Re: QML Questions
how/where did you define username and password variables?
robgeerts
Re: QML Questions
Post by robgeerts »
It's all in the APP-qml:
App {
	property variant devices : []
	property bool devicesReceived: false
	property string username: "base64username";
	property string password: "base64password";
	function getDevices() {
					console.log("Req JSON: "+xmlhttp.responseText);
		xmlhttp.send();
Re: QML Questions
you don't need the ; at the end of a property definition. Not sure if that causes the issues but worth a try
robgeerts
Re: QML Questions
Post by robgeerts »
Ok, for some reason, it did work, so this is a part of my app-qml:
App {
	property string username: "username"
	property string password: "password"
					for (var p in devices){
						console.log("Device: "+p + ": " + devices[p]['Name']);
		xmlhttp.send();
In my screen-qml, i have to following:
Repeater {
	model: app.devices
	SwitchItem {
		idx: model['idx']
In the console.log in the first part of my code above, I get:
Device: 0 : Woonkamer
Device: 1 : Slaapkamer
BUT, for some reason, the variables are undefined (like: model['Name']) in the Repeater (I refer to app.devices in the model-argument, the devices-variable in my app-qml)
EDIT, SOLVED!!!!!
SwitchItem {
	idx: app.devices[index]['idx']
	title: app.devices[index]['Name']
	status: app.devices[index]['Data']
	lastupdate: app.devices[index]['LastUpdate']
robgeerts
Re: QML Questions
Post by robgeerts »
Why doesnt this work (removed code wich doesnt matter in this particular case) ?
I put var status in the text element and it shows me "On" or "Off" correctly but it doesnt show the image.
When I use switchIcon["On"] instead of switchIcon[status] it DOES show the image
Item {
        property string status;
        property variant switchIcon: {
		"On": "./drawables/on.png",
		"Off": "./drawables/off.png"
	Item {
		Image {
			source: switchIcon[status];
    	        Text {
        	        text: status
Ierlandfan
Re: QML Questions
Post by Ierlandfan »
Hi Rob,
(not related to your question)
How do you execute an app? Simply add it to the globals.qml, restarting Qt and monitoring the console?
(And where does that output show up?)
Ierlandfan
Re: QML Questions
Found it:
debugging possible when running the qt-gui manually:
First edit the /usr/bin/startqt and add "exit" on the second line (after the #!/bin/sh line). This will cause the Toon not to restart qt-gui itself anymore.
Add some debugging into your app with "console.log("yourdebugtext")
Then start then qt-gui manually and only look for the debug lines you are interested in: " /HCBv2/sbin/qt-gui -platform linuxfb -plugin Tslib 2>&1 | grep -i yourdebugtext"
Re: QML Questions
try something like this:
source: (status === "On") ? "./drawables/on.png" : "./drawables/off.png"
or make a function SwitchIcon which returns the string for the image
robgeerts
Re: QML Questions
Post by robgeerts »
Toonz wrote:try something like this:
Unfortunately... Still only shows the off image... In the same item (qml) I show 'status' as text and it shows it correctly (on/off)
Ierlandfan wrote:Found it:
Well, this is how I do it now... That works, sort of, but not 'live' while clicking through the app..
Re: QML Questions
can you have a look at ToonstoreDelegate.qml for an example with the last IconButton
robgeerts
Re: QML Questions
Post by robgeerts »
I did... the function it uses there return true or false, just like the if statement I use from your example:
source: (status === "On") ? "./drawables/bulb_on.png" : "./drawables/bulb_off.png"
Also tried == instead of === but no luck :(
Tried change the var name from status to switchstatus, I thought, maybe 'status' is some reserved variable name or something..
EDIT: FIXED!!!
I tried 'data' instead of 'status', both didnt work...
But, because I really was sure the code was correct I tried another variable 'switchdata', this worked!
So, data and status seems to be reserved or something.
