Can you connect with SFTP to you're Toon? Take the VPN keys from it? You will be find it in: /etc/openvpn . if you got lucky you will be find there a tar.gz file names like: eneco-001-0xxxxx.tar.gzNLKris wrote:I've tried to make up a server myself, with linux, but I could not get it working. Is there somebody with a running server to get the Toon alive again? I could drive to your way and if needed I'll pay for the service.NLKris wrote:What did WickedMaster do exactly? I think I might brik my Toon the same way and I just do not understand the unbrick post with webservers etc..
What happend: I did a factory reset, after that I made connection to WiFi so I could root and connect with ssh. When connected to internet the Toon started to download a update. I power off.
Than I started rooting, happend all fine. Than I started the update script witch told me it had to force to 5.2.11. After the download it needed a minute of two. After long waiting the script told me it could not start/finish the update.
So I did the script with -f, it worked..But still wanted to update from 4.20 to 5.2.11. Won't finish the last download part (I think). So after some reading I tried to open VPN, command "opkg update" and "opkg install base-qb2-uni".
Toon told me onscreen it had to reboot after an update. Rebooting in 8..7..6..5.... Anyway, it never rebooted. So I power of.
Than it never startup again. No SSH access. Looked up with COM poort and saw this:
RedBoot partition parsing not available 5 cmdlinepart partitions found on MTD device mxc_nand Creating 5 MTD partitions on "mxc_nand": 0x000000100000-0x000000180000 : "u-boot-env" 0x000000180000-0x000000300000 : "splash-image" 0x000000300000-0x000000600000 : "kernel" 0x000000600000-0x000000900000 : "kernel-backup" 0x000000900000-0x000008000000 : "rootfs"
I hope someone can help me trough step by step (of send me a very clear tutorial). I thank you already for the time!!Code: Select all
Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance. [<c00273d0>] (unwind_backtrace+0x0/0xf0) from [<c029e720>] (panic+0x60/0x190) [<c029e720>] (panic+0x60/0x190) from [<c00223dc>] (init_post+0x78/0xc4) [<c00223dc>] (init_post+0x78/0xc4) from [<c0008b54>] (kernel_init+0x110/0x14c) [<c0008b54>] (kernel_init+0x110/0x14c) from [<c00238ec>] (kernel_thread_exit+0x0/0x8)
I hope that somebody could help my Toon or have some golden steps to do it myself.
Save that thing to a save place...
Only way i think to get you Toon back a life is with NFS and TFTP.. But you need to know what you are doing with it
